camshafts
Old Apr 30, 2007 | 06:44 PM
v6matt's Avatar
v6matt
Default camshafts
are escort xr3i cams and rst ones the same and do the s1 and s2 differ in anyway im on about std items cheers
Old May 1, 2007 | 07:06 PM
Rick's Avatar
Rick
same
Old May 1, 2007 | 09:54 PM
v6matt's Avatar
v6matt
sorry m8 what are the same the s1 and 2 or the xr and rs cheers
Old May 1, 2007 | 10:15 PM
G2RSR's Avatar
G2RSR
Bodybuilding
From: Cannot be identified by the information given.
All mfi ones are the same s1 s2 xr
Old May 1, 2007 | 11:20 PM
SafeChav's Avatar
SafeChav
All MFI cams are the same, EFI cams are the same aswell but slightly re-profiled over MFI cams, all are interchangable
Old May 2, 2007 | 03:16 PM
JesseT's Avatar
JesseT
Ford state two things in their workshop manuals. First, the S1 uses the same cam as the mk3 XR3i, only timed differently with a different cam pulley. Secondly, the mk3 and mk4 XR3i cams are different. So, I would assume that S1 and S2 cams are different too.
Also a fact is that most cvh versions had different cams to each other, but as a replacement part, by Ford or others, same is offered for most. This makes people think that they originally came with identical cams too.
jessie_rs
62
Aug 6, 2019 09:27 PM
Nov 1, 2015 06:53 PM
Marino
Sep 12, 2015 11:10 AM
foreigneRS
Technical essay Archives
Jul 20, 2004 11:29 AM
foreigneRS
Jul 20, 2004 11:06 AM
