splutter
Old Apr 30, 2007 | 09:15 AM
Smoker's Avatar
Smoker
Default splutter
my dopey m8 has just washed his engine with a jet wash with the engine switched off flooding everything in site after many hours of drying we managed to start it but now it strugles to after 5000rpm spluttering and allsorts! any ideas? all info much apriciated many thanks
Old Apr 30, 2007 | 12:12 PM
dazzle740's Avatar
dazzle740
You could try going round the entire engine bay unplugging each sensor plug one at a time cleaning them and try spraying electrical grease into them before plugging them back together this should help the electrical connection and prevent the ingress of water again.
Hope this helps
P.S. if it is a 4x4 dont forget the two big multiplugs at the back of the bay.
Old Apr 30, 2007 | 01:57 PM
You could also dry out the inside of the dizzy cap!!
Old Apr 30, 2007 | 07:12 PM
cossiegreg1's Avatar
cossiegreg1
the bores werent filled with water were they?
Old May 1, 2007 | 01:54 AM
dox's Avatar
dox
water + electrical components = fuk up
Old May 1, 2007 | 09:07 AM
Altratz's Avatar
Altratz
Dizzy cap may be cracked which causes the current to arc accross the points therefor getting a miss fire!
timsrs
Nov 13, 2018 11:48 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
tib2220
Sep 14, 2015 12:33 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
