Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
Mondeo Reverse Light Qu
Old Apr 29, 2007 | 08:07 PM
JayKay's Avatar
JayKay
Default Mondeo Reverse Light Qu
Got my Mondeo booked in for an MoT on Wednesday, anyway was doing the basic checks round it today see if there was anything noticeable that needed doing (e.g. bulbs etc) anyway had it reversed up to my garage door to check brake lights etc and noticed that when I put it into reverse, if I hold the gear lever in gear, the reverse lights are on, but as soon as I let go of the lever, the lights go out? (with reverse still selected and the car obviously able to reverse)
What could be the possible cause of this/is it an easy fix? Ideally wanna do it myself to save cost come MoT time etc..Cars an M reg (MK1) 1.8 TD if that makes any difference
John
Old Apr 30, 2007 | 05:56 AM
Just the switch on the side of the gearbox needs adjusting, in a bit fiurther as it works as a detent plunger.
ps NOT part of MOT either
Old May 8, 2007 | 05:57 PM
tarmac terriost's Avatar
tarmac terriost
i had the same problem with mine like that switch had popped
Old May 12, 2007 | 08:57 PM
djmillsy's Avatar
djmillsy
Fife Radge
as said its not in the mot
Old May 13, 2007 | 08:11 AM
Phil DJ's Avatar
Phil DJ
Either adjust it, check the connection to it or replace it. A replacement would only cost peanuts anyway
S3an
Sep 26, 2015 11:39 PM
S3an
13
Sep 13, 2015 10:01 AM
The Enigma
Sep 12, 2015 10:12 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
gingeRS
Sep 4, 2015 06:29 PM
