cossy sensor
Old Apr 27, 2007 | 07:28 PM
cossie0_4's Avatar
cossie0_4
Default cossy sensor
i have had a lambda sensor boss fitted to my downpipe it is roughly located on the downpipe just before it goes under the car will this still work a afr gauge ok or is it in wrong possition any help appreciated thanks
Old Apr 27, 2007 | 07:30 PM
SafeChav's Avatar
SafeChav
Should be fine, its not as if theres any leakage
Old Apr 28, 2007 | 06:18 AM
As said will be fine , just take a little longer to get up to temp and start working, as close to engine as poss is best due to needing heat as these do not work at all below 300C, but if 3/4 wire is heated and will work ok a lot sooner than one that is not heated.
Old Apr 28, 2007 | 10:40 AM
cossie0_4's Avatar
cossie0_4
thanks for the advice if i was to get a 3/4wire lambda how would i wire the heater wire up cheers
Old Apr 28, 2007 | 12:06 PM
SafeChav's Avatar
SafeChav
If you buy a good wideband setup they should heat themselves and control their operating temperature anyway.
Innovate is where you want to be spending you cash
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
stevecfrst1
Sep 30, 2015 05:18 AM
cossie330
Sep 27, 2015 04:13 PM
