distributor to coil pack question
When removing the distributor to fit a coil pack does the hole on the head need to be capped off? i.e with a gasket or a plug of some kind so no shit gets in the end? Cheers
yes it does mate you can get one from burtons or similar
https://www.burtonpower.com/dets_pro...=97&sTxt=blank
How easy is it to remove what, the dizzy or the blanking plug?
Dizzy - 2X10mm bolts.
Blanking plug - hammer and a punch needed, tap it sideways and remove with a pair of pliers.
Dont think iv ever heard of anyone mentioning it before but i thought it would need blocking
