xr3i efi misfire
Old Apr 27, 2007 | 02:45 PM
d8nno's Avatar
d8nno
Default xr3i efi misfire
my cars is misfirein have replaced the
plugs , leads ,
any idea wat could be causeing it to misfire
any help will be greatful
cars now been off the road for a month please need help with gettin it to run as it should
thanks dan
Old Apr 27, 2007 | 04:08 PM
Dizzy cap, look for tracking marks, is it random, or a regular misfire ?
Old Apr 27, 2007 | 04:22 PM
d8nno's Avatar
d8nno
hi mate its a regular misfire
Old Apr 27, 2007 | 04:28 PM
d8nno's Avatar
d8nno
ive orderd new coil ,and injectors , fuel filter
hopefuly that will be the problem
Old Apr 27, 2007 | 04:36 PM
As it's regular most likely a problem only on one cylinder.
Leave it running and pulleach plug lead in turn to see which one.
If this makes no difference then try the disconnecting each injector inturn so as to identify dodgy cylinder, then do a compy test to determine what it is.
Old Apr 27, 2007 | 04:39 PM
d8nno's Avatar
d8nno
Leave it running and pull each plug lead in turn to see which one
what dies or make a diffrent noise
Old Apr 27, 2007 | 05:54 PM
If you get to a cylinder that makes NO DIFFERENCE, you know it is not doing anything!!, so at least you will know which one it is.
Old Apr 27, 2007 | 08:46 PM
gup's Avatar
gup
have you checked to c if you have a spark at the end of each lead by the spark plug as it could be the coil pack breaking down
Old Apr 28, 2007 | 06:20 PM
efiste2's Avatar
efiste2
as GUP says, coil pack is common problem on the EFI mate, worth investing in a fault code reader too, it could save you replacing bits that dont need replacing,
stephenb4506
33
Oct 2, 2015 06:25 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
dms04
Sep 11, 2015 01:57 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
