actuator question
Old Apr 27, 2007 | 01:08 PM
andre_k's Avatar
andre_k
Default actuator question
how can i tell if my s2 is fitted with a -31 actuater, whats the differance between that and a standard one?
Old Apr 27, 2007 | 01:09 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
on the top surface, there will be some digits, the last ones will be -31
Old Apr 27, 2007 | 01:10 PM
xr4x4rs's Avatar
xr4x4rs
im usre the genuine garret actuators have -31 stamped in them at the back
Old Apr 27, 2007 | 01:22 PM
As said just written on front.
Old Apr 27, 2007 | 02:56 PM
cozmeister's Avatar
cozmeister
More boost Igor!
The difference between the standard -18 (on a Cossie anyway) and a -31 is that the -31 has a stronger spring, which holds the wastegate shut longer, reducing the time it takes the turbo to spool up
Old Apr 27, 2007 | 04:25 PM
It does not affect spool up at all, it merely holds the wastegate shut against MORE pressure so it can provide more, but the spool is not affected as pumping remains the same.
Old Apr 29, 2007 | 05:06 PM
andre_k's Avatar
andre_k
its just im getting a chip on my s2 on weds and i was wondering if my actuater is a -31
it is needed for 14 or so psi on a s2 isnt it?
i will take a pic shortly
Old Apr 29, 2007 | 05:45 PM
14psi will need -31, printed on the last numbers on the front ie *****-31.
Old Apr 29, 2007 | 05:51 PM
andre_k's Avatar
andre_k
cant see any numbers ...
Old Apr 29, 2007 | 07:09 PM
Wind it up if it wil not hold 14 either it is knackered or you need a -31 so either way you need one!!
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
