To back pressure, or not to back pressure?
That is the question
Some people have told me my ERST need to have some back pressure to keep the oil seals in the turbo ok, others have told me that it doesn't as the gases need to flow out as quickly as possible.
I'd be grateful if someone could confirm this as I hatching a cunning plan.
It isn't running a standard set up, so I am wondering if this would make any difference?
K&N Filter (with cold air feed)
Full 2.5" stainless with one backbox and 3" tail
Turbosystems 195 chip
running 14psi
Cheers for the help guys
running 14psi
THERE ARE NO SEALS,as such, if std turbo, so one myth gone.
A certain amount of backressure is indeed beneficial to oil control past the turbo shaft, but you can have the turbo rebuilt with 360 and STEP GAP SEAL which will ALMOST totally control the oil loss, through the turbo.
Losing backpressure can allow it to develop more power, and a lot more noise!!
Standard T3's have the dynamic ring seal.
Phil79 as tabetha is saying though, on a standard T3 they have just a standard dynamic ring seal, which basically like a piston ring, has a tiny tiny gap in the seal, and it relies on simple physics to contain the oil within the turbo, so in this case the back pressure in the exhaust exceeding the oil pressure within the turbo core.
If you start fitting large diameter exhaust systems you majorly reduce back pressure and its common for the oil enter the exhaust, so a step gap seal is what you'll want in your turbo to control this, which basically means there is no straight gap in the sealing ring
PassionFords Creator
OK, so we took the backbox out of the system last night (well, Geoff @ CSG did, I stood and watched
Sounds mean as you like now, proper growly, but looks like it lost around a pound of boost. So, as you do, I gave the death valve a twist to sort that out, but now it seems to have a bit of a flat spot.
If I accelerate in 3rd, it loads up as usual from 2800......... then at 4000 its like being hit in the back by another car
Really comes on song, screams away and off I pop down the road. Strange.
Can MFi have flatspots pulled out with a decent set up by a tuner, or is that only EFi?
)Sounds mean as you like now, proper growly, but looks like it lost around a pound of boost. So, as you do, I gave the death valve a twist to sort that out, but now it seems to have a bit of a flat spot.
Just out of interest why have you removed the back box
sounds like a recipie for disaster
I seemed to have lost a pound or two of boost, so I wound the valve out a little until I can get a new actuator. Surely the bleed valve does the same job as pre-tension on the actuator?
I do have a gauage and I don't let it go above 1 bar, which is safe as it's set to run 18psi.
And I took the backbox off because the weld around it had split and thought that, if a pressureless system wouldn't cause any harm, then I would just replace it with a piece of straight pipe.
mrmann
Aug 20, 2015 11:24 PM
Red_bull
Aug 9, 2015 08:34 AM
