cosworth engine problem
Old Apr 26, 2007 | 10:07 PM
rs nuts's Avatar
rs nuts
Default cosworth engine problem
recently i purchased another cosworth with a nice engine spec until recently
came home the other day and the car just dident sound the same on tickover
so i compression tesetd it and all the borese exept number 3 were on about 130 psi and number 3 was on 80 psi
my engine spec is low comp and is 7.4 , studded block with wrc headgasket ,ported and poished head with bd 10 cams
so i take the rocker cover off and have noticed some rocker caps are loose and the nuts have neally come all the way off ,and which has caused some studs too strip out off the head
so i carry on and take the head off as no real problem headgasket and stud reusable
i was expecting too see something wrong but everything looks ok
no valves look bent and no bore sacrapes and pistons look ok
any suggestions too what could be the problem
as i have been told the tappet could be stuck or drained off oil due too the rocker bolts being loose which whould cause loss off psi in bore 3
any help or info much appreciated
head being sent in too get studs sorted that have stripped and also check the valves over
Old Apr 27, 2007 | 07:32 AM
A stuck tappet will NOT Lift the cam out as suggested, because the valve is weaker than the caps, this will bend/break first.
It is yet another cossie that has been abused by not being put together right.
Old Apr 27, 2007 | 07:10 PM
Alvyn's Avatar
Alvyn
if the cam caps were loose the the valves WONT be working correctly ie opening and shutting at the right times If at all, doubt they'd be able to of opened enough to make contact with the pistons either so DONT think you have bent any valves imo and the compression WOULD of been lower because of that!
Old Apr 27, 2007 | 08:27 PM
rs nuts's Avatar
rs nuts
cheers chaps , the head has gone in for inspection and is haveing the stripped studs ali coiled
also he said today he will recut the valves in and make sure nothing else is wrong
so hopefully back on the road next week
Old Apr 27, 2007 | 08:38 PM
Alvyn's Avatar
Alvyn
one other thing that springs in mind do have the condition of the cams checked as have known a few to snap in 2 pieces due to caps being lose!
Old Apr 27, 2007 | 08:40 PM
rs nuts's Avatar
rs nuts
yeah that has happend too me in the past
they have not snapped thats the first thing i checked
surely they cant bend or am i mistaken?
i hope they are ok as they are bd10 cams on both sides
Old Apr 28, 2007 | 06:15 AM
The fact that you had perfect compression ion three cylinders shows the valves were opening and closing.
Make sure you get three angle seats on valves, and being a cossie head guides and exhaust valves COULD be knackered too!!.
Old Apr 28, 2007 | 06:23 AM
rs nuts's Avatar
rs nuts
cheers , the head is in the engineers shop now and he is checking all the valves for me just too make sure
Old Apr 28, 2007 | 06:37 AM
Yes you don't want to skimp as it will come back and bite you in the wallet!!
Hope it is not too bad for you, keeping my fingers crossed.
Old May 3, 2007 | 09:00 PM
rs nuts's Avatar
rs nuts
car is fixed and runs better than ever
it had pulled 7 studs out which hold the cam caps down ,so they was allicoiled
damaged 3 valves
so them was replaced and had all the valves decarboned and reseated
only cost me 100 too get done as i had spare valves
rebuilt it tonight and the car is spot on well chuffed
thx too you who helped with the input
Old May 4, 2007 | 07:04 AM
Good result there, no speeding now!!
Old May 4, 2007 | 05:06 PM
rs nuts's Avatar
rs nuts
ive not even gone 3 miles and the valve has dropped and smashed my head and piston too bits
engineer dosent want too know i am so pissed off
now the car is getting broke for parts ive had enough
Old May 4, 2007 | 05:43 PM
F****in hell, that's not good.
Engineer has some answering to do IMO.
If you were nearer I would put it together for you FOC, but make sure all ok first, you should be able to trust engineers work, can't see how it could be down to you.
Old May 4, 2007 | 08:04 PM
timster's Avatar
timster
thats shit luck,gutted for you fella
Old May 4, 2007 | 09:06 PM
rs nuts's Avatar
rs nuts
car will be in the cosworth for sale parts with in the next couple off days
the big brakes and turbo and coilovers are already spoken for
ive got another head so im getting the bottom end sorted out and building it back together and then thats for sale aswell
thats it for me now with cosworths time too move on
Old May 5, 2007 | 05:54 PM
rs nuts's Avatar
rs nuts
change of plan
i neally started too strip today but the car is just too good for that
im getting my other head sorted and im getting the spare 4x4 piston i have machined down too match the others and hopefully be back on the road soon as the others are 4x4 pistons which have been machined down
fingers crossed cant afford any more misshaps
big_Rad
Sep 15, 2017 09:36 AM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Aug 14, 2015 07:29 AM
wheelwizardrefurbs
Aug 6, 2015 07:40 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
