s2 head
Old Apr 26, 2007 | 09:07 PM
lewis_lisa's Avatar
lewis_lisa
Default s2 head
hi my s2 has just passed its mot and will be out next week the only prob is i still have a knock at the head and is worse when engine has just started then is a bit better when i give it some the car goes then misfires and holds back the car has been sitting pretty empty on fuel for a while and ive ran out a few times as my gauge aint up to much it also needs a set up as sometimes fueling is out are all these probs connected
cheers lewis
Old Apr 26, 2007 | 09:10 PM
T28 RST's Avatar
T28 RST
Ok then
Only one answer
Get it set up ay AVA
Old Apr 26, 2007 | 09:11 PM
T28 RST's Avatar
T28 RST
Ok then
Lewis i will need to have a wee run against you once your car is running properly
Old Apr 26, 2007 | 09:49 PM
SafeChav's Avatar
SafeChav
Fill the tank up with some decent fuel and take it for a long steady run and see if any of the top end noise improves. Sounds like a knackered hydraulic lifter to me personally.
Old Apr 27, 2007 | 12:01 AM
lewis_lisa's Avatar
lewis_lisa
nice 1 davie
safechav: is it o.k to run the car as long as i dont put it under load as im going to a few shows in next 2 weeks
Old Apr 27, 2007 | 12:14 AM
SafeChav's Avatar
SafeChav
i wouldnt like to put a definate answer on that, but if you have to drive it, driving it gently is going to better than boosting it up.
It'd be best if you can just get it fixed though
Old Apr 27, 2007 | 01:13 AM
lewis_lisa's Avatar
lewis_lisa
cheers m8 will take it to rr and get it checked out
Nov 1, 2015 06:53 PM
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
