Converting my FRST from OFAC to OFAB
Old Apr 26, 2007 | 08:57 AM
Fiestamatt's Avatar
Fiestamatt
Default Converting my FRST from OFAC to OFAB
to cut a long story short i have a spare ofab ecu and chip, my currecnt ofac ecu and chip i think are on their way out.
How hard is it to convert my current loom and setup to accept the OFAB ecu and chip.
Thanks in advance
Matt
Old Apr 26, 2007 | 10:28 AM
SafeChav's Avatar
SafeChav
As i said to you before, you HAVE to have a Marelli MAP sensor to run OFAB.
Old Apr 26, 2007 | 05:40 PM
rauri's Avatar
rauri
up in smoke........
are the edis units and co pot thingys interchangable tho?
Old Apr 26, 2007 | 06:25 PM
SafeChav's Avatar
SafeChav
yea they are all the same
Old Apr 26, 2007 | 06:51 PM
rauri's Avatar
rauri
up in smoke........
safechav you are a fountain of useful information m8
so erm using a 3 bar on ofab...keep the suppressor or ditch it?
Old Apr 26, 2007 | 06:53 PM
SafeChav's Avatar
SafeChav
The suppressor should be kept, but you can't just plug a 3 Bar in and run it, get your wallet out cos you need a chip
Ive got OFAB here i bought a year and half ago but im going to run megasquirt now
Old Apr 26, 2007 | 07:08 PM
rauri's Avatar
rauri
up in smoke........
yeah i know i need a chip,thats under control
ive swapped from ofac to ofab and was wondering what bits i can keep and what bits i need to replace.thing is my loom i got had the supressor removed (plug too ) so i need to get a new plug and supressor?
Old Apr 26, 2007 | 08:31 PM
SafeChav's Avatar
SafeChav
You sure its been removed? Earlt FRST's didn't have suppressors i believe.
Old Apr 26, 2007 | 09:14 PM
rauri's Avatar
rauri
up in smoke........
ahhh that could explain it,i compared against a ofab loom my mate is using for his bonus sleeper and where he has the bit for the supressor i dont have anything
so will it run ok without one (obviosly having a correct chip for my set up)
Old Apr 26, 2007 | 09:43 PM
SafeChav's Avatar
SafeChav
It will run, obviously they got fitted on later ones for a reason but it shouldnt be too much of a drama if you dont
mondeomark
Sep 28, 2015 06:28 AM
jonnyenglish
Sep 21, 2015 07:31 AM
gambo08
Fiesta RS1800/RS Turbo
Sep 16, 2015 08:10 PM
Neil Clark
Sep 8, 2015 07:06 PM
hopper350
Sep 4, 2015 12:53 AM
