What connects here? MFI picture identification,this right?
can some helpful people help me finish plumbing in my RST conversion
i have these three small unions to connect up
the air hose to the actuator and the union on the turbo housing - both seen in this pic
and this pipe on the metering head
do they connect to the amal valve? i don't think i have one what does it look like.
could someone also have a look at these and check theres nothing glaringly obvious wrong
If you have no amal valve, block the one on the metering unit up and conect the actuator - compressor housing on the turbo, it will boost to whatever the actuator is set too so obviously you'll need to adjust the actuator to suit the boost you need!
get it on a RR when you get it running anyway imo
Originally Posted by ScORTED
yeah will take it to an RR - should i connect the bleed valve inline with the actuator/turbo so i can manually set the boost limit?
Mark RS
Oct 12, 2015 06:01 AM
Kiran1600E
11
Oct 2, 2015 11:35 AM
