Piston identification
Old Apr 25, 2007 | 08:34 AM
nellrodd's Avatar
nellrodd
Default Piston identification
Can anyone shed some light on the make of these pistons. I pulled these out of my S2, the block is meant to be a 1900cc, verniered the bores and they are 83.2mm. Pistons are meant to be forged but i wouldnt know the difference!! It has A.P.L 1001 stamped underneath the piston.
[/url]http://i171.photobucket.com/albums/u303/nellrodd/DSCN0492.jpg
[url]http://i171.photobucket.com/albums/u303/nellrodd/DSCN0493.jpg
Cheers,
Neil[/img]
Old Apr 25, 2007 | 08:39 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Old Apr 25, 2007 | 12:41 PM
SafeChav's Avatar
SafeChav
Ah i see so theres 2 threads on this eh
Christian i re-hosted them for him aswell
Old Apr 25, 2007 | 05:09 PM
ivorbiggun's Avatar
ivorbiggun
They look like the original pistons out of an early (85/86 carb) American
1.9 cvh.
If (Big If) they are forged someone has paid a lot for them to be specially made.
It's a long time since I looked at any standard ones so I can't remember
what markings they had on them, sorry.
What casting marks have you got on your block?
Old Apr 26, 2007 | 10:05 PM
nellrodd's Avatar
nellrodd
ivorbiggun,
thanks for your input there, you may be right as the block was meant to be a 1900cc!! I will check the block for numbers in the morning and get them posted up. This is more out of interest than anything else. They look fairly new (pistons) but that could mean anything.
Cheers,
Neil
Old Apr 26, 2007 | 11:28 PM
SafeChav's Avatar
SafeChav
Get a picture of the block up so we can see if its a 1.9 block or not.
Old Apr 27, 2007 | 07:34 AM
nellrodd's Avatar
nellrodd
Well considering the hash of things i made trying to get the pics up in the first place!! How do you go about posting pictures up folks??? A step by step if you please?
Cheers,
Neil
Old Apr 27, 2007 | 09:54 AM
SafeChav's Avatar
SafeChav
Don't be daft, you just used the wrong link from Photobucket.
Use the bottom of the 3 links in photobucket (IMG link) and paste it in, job done
Old Apr 27, 2007 | 04:09 PM
ivorbiggun's Avatar
ivorbiggun
If it's the block that corresponds to the pistons I think they are, it should
have a '27' cast both sides of block.
Old Apr 27, 2007 | 04:57 PM
nellrodd's Avatar
nellrodd
Okay here's the pics. But as its got 16 on the block either side im guessing its a 1600cc block bored out to 1900cc.
IMG]http://i171.photobucket.com/albums/u303/nellrodd/DSCN0501.jpg[/IMG]
Cheers,
Neil
Old Apr 27, 2007 | 05:13 PM
ivorbiggun's Avatar
ivorbiggun
Looks like one o them thar overbored 1.6's, there doesn't seem to be
much liner left around those pistons does there?
Old Apr 27, 2007 | 05:23 PM
crazycage's Avatar
crazycage
i think the 1900 blocks have cvh stamped on the back of the block ,i would say yours is a 1600 as it has 16 on the back of it
Old Apr 27, 2007 | 05:34 PM
ivorbiggun's Avatar
ivorbiggun
If you've got the crank still in there, measure the stoke.
If its 88mm its a (according to some) 'proper' conversion
if it's still 80mm then oh oh it's a 1740..
Don't worry too much though the 1.9 from the factory was only
in reality 1860cc.
Old Apr 27, 2007 | 06:04 PM
ivorbiggun's Avatar
ivorbiggun
Yes they do but just to confuse things a little more so does the 2 litre.
Which is in fact more like what we know as a zetec.
Old Apr 27, 2007 | 06:48 PM
crazycage's Avatar
crazycage
my 1800 has cvh on the block
Old Apr 27, 2007 | 07:07 PM
nellrodd's Avatar
nellrodd
My guess is that its a bored out jobby, considering the 16 on the block. To be fair though, it was more out of interests sake thatn anything else. Just wanted to get some info on her!!
Another pic from above to show the liner. I have done a dye penetration test for cracks of the bores, the block face and where the crank connects for the oil ways. All came out fine.......... Thankfully!!!
I dont have the crank as its away being reground and balanced at the moment, ill try when i get it back. I would think that with the fact the bores are a couple of mm larger, it must be bigger than 1600cc.
Thanks,
Neil[/img]
Old Apr 27, 2007 | 07:12 PM
SafeChav's Avatar
SafeChav
Definately a 1.6 block, no doubt about that.
Obviously as you say though its bored out so its going to have more capacity.
Old Apr 28, 2007 | 02:24 PM
Fiecos Dan's Avatar
Fiecos Dan
The finish on the pistons look forge, or machined cast(which i have never seeb before)
Nov 1, 2015 06:53 PM
little bram
Oct 4, 2015 12:13 AM
deathrider666
Sep 28, 2015 06:12 PM
timsrs
22
Sep 24, 2015 08:14 PM
ajamesc
Sep 8, 2015 06:51 PM
