MK4 Escort XR3I EFI Electronic Water Temp Gauge Fitment Help
Old Apr 24, 2007 | 11:46 AM
jedi0_3's Avatar
jedi0_3
Default MK4 Escort XR3I EFI Electronic Water Temp Gauge Fitment Help
Good Afternoon.
I have the above to fit, it comes with it's own sender same size as original Ford one but does the ECU use the signal from this sender at all and if so does it need the Ford one and do I need to use a T Piece adaptor to have both senders installed or can I just install the new gauge sender & piggy back the dash temp gauge wiring off of that if the ECU is unaffected?
Thanks again!
Old Apr 24, 2007 | 12:36 PM
ECU should have it's own sender.
You will have problem if the ford sender and the new sender do not match, ie are a different resistance as the reading then will be incorrect for the new guage, try it and see.
You should be able to see the temp sender for the ECU as it will be a lot bigger and will have at least three wires going to it usually near the thermo housing ?
Old Apr 24, 2007 | 03:13 PM
jedi0_3's Avatar
jedi0_3
Thanks again Tabetha
Old Apr 24, 2007 | 03:18 PM
No probs chappy.
Old Apr 24, 2007 | 06:42 PM
SafeChav's Avatar
SafeChav
Which sender are you talking about?
If you're talking about the sender for the standard gauge then no the ECU doesn't use it.
Old Apr 25, 2007 | 08:14 AM
jedi0_3's Avatar
jedi0_3
Yet again, thanks safe Chav
Old Apr 25, 2007 | 11:27 AM
SafeChav's Avatar
SafeChav
No worries
manuel boeckx
13
Oct 3, 2015 02:29 PM
FlashRS
Sep 14, 2015 12:36 PM
EoinXR3
Sep 7, 2015 05:44 AM
Vincereese
Aug 18, 2015 03:57 PM
Bloody-Fox
Aug 3, 2015 07:48 PM
