cossie misfire
Old Apr 22, 2007 | 10:57 AM
sjm's Avatar
sjm
Default cossie misfire
this started as a intermitant problem but it's now doing it all the time. it drives fine of boost once it's warmed, but under big load sort of over 4000 rpm it just pops and bangs like guy forks. ive tried the obvious like plugs and leads, i'm running a recently purchased group A coil, ive tried a new ignition amp. i know the cps sensor connections are sometimes troublesome as ive had it before - so i soldered that back then.
could it be the phase sensor? if so how do you know they are gapped correctly when replacing?
could i not be using suitable plugs?, i was running ngk R iridium, when everything was spot on, put out a strong 357 on the dyno that week. then the problem started so ive borrowed my mates champion c57's i thing, they've not helped. stu at msd reckons denso iridiums are the ones to use, does anybody know which ones? (running greens, t34.48, 28 psi)
all of which has ruined my weekend as i wanted to be at santa pod today, to try and the 13 sec mark.
Old Apr 22, 2007 | 11:15 AM
sjm's Avatar
sjm
ive just ordered a new dizzy cap, arm and phase sensor from msd. so any advise on the setting of the phase sensor would be a great help.
Old Apr 22, 2007 | 03:16 PM
jon@work's Avatar
jon@work
phase sensor gap 0.2-0.3mm
talk to Stu as to which Iridiums he recommends you use
Old Apr 22, 2007 | 03:17 PM
KSA-Cossie's Avatar
KSA-Cossie
IK27 iirc
Old Apr 22, 2007 | 04:41 PM
sjm's Avatar
sjm
is there anything else that may cause this problem?
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
