De-Locking
Old Apr 22, 2007 | 08:36 AM
smudge_lad's Avatar
smudge_lad
Default De-Locking
3rd post in as many minutes, sorry guys......
De-locking an Orion - what happens if the battery goes flat or the alarm buggers up and the cetral locking doesn't work - how do you get in????
With my gf's ERST, simply open the boot and climb in!
Can the seats be pushed down from inside the boot?
Old Apr 22, 2007 | 11:13 AM
2wdsaph ben's Avatar
2wdsaph ben
on my orion which was a h plate you could unlock the boot with a key then in the boot opening at the top there is a black round plastic handle on both sides pull them and at same time push back of seat then they folded back.
ben
Old Apr 22, 2007 | 11:34 AM
smudge_lad's Avatar
smudge_lad
cool, im in work at the moment, so will check when I finish.
Just a bit worried about the car being broken into etc, thought about de-locking, and possibly removing rear door handles?? Is this legal/possible/sensible?
Old Apr 22, 2007 | 03:55 PM
Alvyn's Avatar
Alvyn
jack the car up and put leads to the starter motor my saff has no exterior locks
Old Apr 23, 2007 | 12:19 AM
SafeChav's Avatar
SafeChav
This is why you should always carry a brick around with you
Yes you can climb in through the boot. If the battery went flat you can conenct a power supply to the starter motor feed to unlock the doors!
And if your alarm fucks up you obviously have a Clifford
t31ryt
Aug 10, 2009 09:21 AM
joe s
59
Jun 29, 2009 05:07 PM
t31ryt
PassionFord Swap Shop.
25
Jun 27, 2009 01:37 PM
escort1989uk
Mar 2, 2005 08:42 PM
Hrsturbo
12
Oct 22, 2004 05:29 PM
