Cosworth Torque setting (ARP)
Passion for Fords!
Does anybody have these torque settings handy?
ARP head stud and nut kit
ARP big end bolts
Standard main bearing bolts
Oh and also if possible the dial in figures for standard 4x4 cams?
Many thanks!
the engine is going back together
ARP big end bolts
Many thanks!
Head bolts : 40nm / 80nm wait 20min then 110nm warm engine up to normal then cool down, then loosen a 1/4 then re-tighten to 110 one nut at a time. (this procedure works perfekt on my cars)
Crank : 90nm
Rods : 60nm
dial in figures for standard 4x4 cams? what does this mean?
Crank : 90nm
Rods : 60nm
Originally Posted by JTECHSAFF
so i can dial the pulleys in (vernier)
how can i torque a small end?
i want big ends and main bearing torque
(I`ve just corrected the text for u)
Why do u have to time the cams?
U bought ajustable verniers?
yeah i got quaife ones, need the figs so i can dial them in later.....
thanks for the figs!
If your really at it, then put the quaife one on top of the orriginal, then u can match them up no problem.
Passion for Fords!
i can do that to get them near enough, but using a dti gauge with these pulleys i will be able to get the cam timing exactly 100% right. if i have the figs.
using the standard marks isnt over acurate.
Good luck
Oct 9, 2015 07:38 PM
Aug 14, 2015 07:29 AM
