cambelts, whats the tensioner? does it always get replaced?
Old Apr 19, 2007 | 02:32 PM
Cawood's Avatar
Cawood
Default cambelts, whats the tensioner? does it always get replaced?
when changing the cambelt, whats the tensioner
i guessing its something to do with adjust the tension of them cambelt? involved with setting it up?
do you always replace these when doing the cambelts? do they have to be replaced everytime?
i dont understand it fully, can anyone shed a bit of light?
cheers and yes i know im stupid
Old Apr 19, 2007 | 02:39 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
You don't have to replace the tensioner
Steve.
Old Apr 19, 2007 | 02:43 PM
Daveyboy's Avatar
Daveyboy
but its advisable to.....
Old Apr 19, 2007 | 02:46 PM
Rolls's Avatar
Rolls
Yeah, for the sake of 30 quid for a new tensioner and bolt i would replace it too
Old Apr 19, 2007 | 02:48 PM
mark_24v_wiring's Avatar
mark_24v_wiring
Steve.
You do if its a zetec engine its storngly advised to change tensioner and idle pullys
So i guess it would depend on what engine were talking about
Old Apr 19, 2007 | 03:07 PM
Cawood's Avatar
Cawood
cheers lads but more trying to find out what it does n stuff rather than should i replace it or not (im replacing it anyway)
just wondered, just trying to understand what it does and why it should be replaced?
Old Apr 19, 2007 | 03:16 PM
bud-weis's Avatar
bud-weis
Football Cwazy
basically it's there to keep the cam belt at the correct tension, it bolts to the cylinder head and then once the cam belt is fitted it is adjusted outwards against the belt to increase the tension.
it needs replacing because it runs on a bearing and there's a fair bit of stress on them, the bearings wear with age and can basically break or loose tension fucking your cam belt/head/engine.
Old Apr 19, 2007 | 03:34 PM
Cawood's Avatar
Cawood
bang on, cheers martin. i understand that
Old Apr 19, 2007 | 03:46 PM
RichieST's Avatar
RichieST
i've heard of more cars with tensioner failure than cambelt failiure, so yes, you would be stupid not to change the tensioner and any idler pulleys when doing the cambelt just for the sake of a few extra quid
Old Apr 19, 2007 | 04:21 PM
Deleted by Request's Avatar
Deleted by Request
Former Sponsor
....all you need to do is spin the tensioner if it runs nice and smooth and silent its ok..if not replace.
Mc5506
Oct 5, 2015 09:57 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
