Zetec TPS Wiring
Apr 19, 2007 | 01:44 PM
Zetec TPS Wiring
Any one know the pin configuration.
Is it the same as a cossy ST one?
Apr 19, 2007 | 03:16 PM
Apr 20, 2007 | 08:41 AM
anyone ?
3 Pin is Sensor Ground ( i know this)
Pin 2 is a White wire
Pin 1 is a Yellow wire
Apr 20, 2007 | 10:20 AM
I can get you a picture of a TPS off a mondeo inlet, fiesta inlet and a focus inlet if that helps at all?
Apr 20, 2007 | 10:24 AM
all sorted now i tihnk.
cheers anyway
Apr 20, 2007 | 10:28 AM
what year focus and spec you looing at ryan?
Apr 20, 2007 | 10:31 AM
1 ground
2 signal
3 supply
Apr 20, 2007 | 10:59 AM
not that gareth sensor ground was definately on 3, so must have been an early zetec.
I know the later ones are as you said.
DixieTheKid
11
Jun 6, 2020 11:20 AM
TPM961
Jan 15, 2018 10:50 AM
SMILER258
Sep 28, 2015 09:04 AM
IainRS1700T
Sep 25, 2015 06:44 AM
focuspower
Sep 20, 2015 03:51 AM
fiesta ,
focus ,
ford ,
mondeo ,
pin ,
position ,
sensor ,
signal ,
throttle ,
tps ,
wire ,
wires ,
wiring ,
zetec
