Advice on engine/megasquirt/manifold
Old Apr 15, 2007 | 03:48 PM
banditbarron's Avatar
banditbarron
Default Advice on engine/megasquirt/manifold
Need your help guys, I've been offered a 2.0 zetec fro a mondeo thats been stripped and had belts replaced and some seals and other little bits replaced. Also a megasquirt v2, and a 4-2-1 manifold. Basically i plan to fit all this into my fiesta si but i want to know if you think all the above is worth the £400 he wants for it all? and if anyone knows anything about the v2 megasquirt any help/advice would be greatly welcome. I've put some pix up of whats on offer so please advise me guys. Cheers Dave.
Old Apr 15, 2007 | 04:09 PM
SafeChav's Avatar
SafeChav
If the engine is in a good state then thats got to be worth it.
V2 megasquirt is supposed to be the better of the ones available i do believe, lots of extra code available to allow you to do pretty much anything you want.
Old Apr 15, 2007 | 05:42 PM
Wardy257's Avatar
Wardy257
I would make sure it is a 2.o ltr and check the water pump and sump have been changed to suite the Fiesta.
Old Apr 15, 2007 | 06:02 PM
banditbarron
He's saying he's changes all the parts over to fit straight into fiesta sothat should be ok. Was just concerned the manifold looked a cheapo one and if thats all thats needed for the megasquirt?
Old Apr 15, 2007 | 06:24 PM
fezski's Avatar
fezski
As Wardy said.......have alook at the block behind where the exhaust manifold should go, will have 2 0 cast into it if is a 2.0l. Is always worth double checking. I was going to say from the pic it looks like the waterpump pulley is multi-vee+alternator positon and rear engine mount would suggest its already been converted to run in a escort/fiesta.
Exhaust manifold looks like an ashley 4-2-1 but the second half welded up with bolt on flange.......Other than that its a good deal. I found Megasquirt can be abit tricky to install. Not trying to put you off, its a good ecu once you`ve got your head round it *I got there in the end* but theres plenty of help on the MS forums if you have any problems.
Old Apr 16, 2007 | 11:55 PM
banditbarron
any more comments please post??????
Old Apr 17, 2007 | 04:39 AM
JesseT's Avatar
JesseT
Comments and comments... When you have some specific questions, I'll be glad to help. Just go on with the project for now. Sounds pretty straigth forward.
Old Apr 17, 2007 | 07:47 AM
banditbarron
I would like to know if that megasquirt willjust piggy back the cars ecu or what? And what sofware/extra bits i'll need to run the set upon my laptop? cheers.
Old Apr 17, 2007 | 08:20 AM
ShandzS1's Avatar
ShandzS1
I would like to know same question? But why do u need megasquirt if ur using standard manifold set-up?
Old Apr 17, 2007 | 08:23 AM
banditbarron
this is what i'm unsure of the guy selling it is saying its more of an advantage to have it running on the car than the standard ecu and has apparently already been set up to run the engine in a fez properly?
Old Apr 17, 2007 | 12:52 PM
SafeChav's Avatar
SafeChav
Megasquirt is a replacement ECU for a standard one, not a piggy back.
Its a very affordable version of any after market ECU such as Omex/Gotech/Pectel etc
Old Apr 17, 2007 | 03:09 PM
JesseT's Avatar
JesseT
Start from here:
http://www.megamanual.com/v22manual/mtabcon.htm
The most common tuning software for windows is known as "Megatune", but there are others for Unix, Palm, etc...
mk3ste
Oct 17, 2021 10:09 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
rsguy
44
Sep 29, 2015 03:29 PM
Marv888
Sep 26, 2015 03:44 PM
