Zetec turbo - cossie plugs
I'm in the middle of a zetec turbo build with the head and block currently at the engineers, ive heard that cossie plugs are generally used on this conversion requiring the head to be retapped,
can anyone tell me what the benefits are and what work is involved?
many thanks
many thanks
If you wish to run any more boost than approx 15psi, then the best zetec based plugs out there will fall apart on you (risking serious engine damage). Obviously cossie plugs are available to suit any state of tune, so this is why the work needs to be done.
Its a very simple engineering procedure really, the head just needs to be milled vertically, shortening the threaded hole in the head so that when the cossie plug is fitted, it sits in the correct place. The spark plug threads are the same, so there is no tapping / re-tapping to be done.
Hope this helps
Hope this helps
Ł30 or so to modify the head whilst its off and at the engineers.... versus getting some plugs imported from the states
Ello Phil, alright?
As for Focus RS plugs - not sure about that as a solution. I think Paul J used them and had a tip fall off, but im not 100% sure on that. Im fairly certain A plug tip melted on his, and did some damage to the head / valves or something, so worth doing the cossie plug mod IMO!
Ello Phil, alright?
The problem i had was caused by normal Zetec ones which WILL fail at a bar+. Proved over and over until serious damage was done
I have found the RS one's so far to be spot-on @20psi tho. (my problem with the first set was specific to my car Sketch
TBH i would for the minimal cost have it machined, then slot in so NGK 9s from Stu.
If you want to use NGK 9s, they USED to cost Ł70 delivered from most places, although im not sure on the current price as a new version has just been released or something. Something to bear in mind though is that you need a different version of the 9s than what the cossies use (assuming you are using a coil pack on your engine). The cossies use R7234-9 and you need R7235-9. Using the wrong version will result in a small misfire issue as Stu @ MD can confirm ( i hope
They should last quite a long time - they are the most highly reccomended and used plug (i would imagine) for the bigger powered cossies (ie 330+bhp)!!
Billy_RS
16
Oct 11, 2025 09:41 PM
