Big Valves
Old Apr 13, 2007 | 09:27 PM
richard_syko's Avatar
richard_syko
Default Big Valves
Can larger valves be used without replacing valve seats? If so how much larger (silver top Zetec I=32mm E=28mm)?
What kind of price can I expect to pay to have valve seats replaced?
Rich.
Old Apr 14, 2007 | 06:56 AM
NO & LOTS!!
Larger valves need larger seats for them to work, they work by offerring more airflow potential, and they will cost a bit to get in, as have to be cut in, IF THERE IS ENOUGH MEAT on the head!!
Old Apr 16, 2007 | 12:17 PM
Maki's Avatar
Maki
I wouldn't say so... I've just fitted one millimeter larger valves into my CVH head... the seats themselves were machined by 2 mm.... I'd say it depends on the head you are doing. From my experience it can be done on CVH... don't know about zetec
Old Apr 16, 2007 | 12:21 PM
Is there any point in 1mm larger though for the cost ?
Old Apr 16, 2007 | 12:26 PM
Maki's Avatar
Maki
In my case probably not much as standard unmoded zetec head would flow more air then big valve CVH But still every bit gives you gain in power (I'll use it on 2.0 bottom, so I needed better flowing head)
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Nick 172 Sport
Sep 28, 2015 07:21 PM
