Cosworth starting problems and grey-blue smoke
right....i had my cossie out around a week ago for its first time in months, and it seemed to be runnin reely well. I tried to start it up yesterday and it took along time to fire and when it eventually started was only running on 1-2 cylinders and chuckin alot of grey-blue and white smoke out (smelt petrolly). Now ive changed the plugs and its just the same. initially we thought the turbo had gone but theres now play in the shaft at all and spins freely....brief spec: 8 greens, T4 low comp....any ideas?
thanks
Dave
thanks
Dave
i think the fact you are suggesting a compression check is because u suspect it has knackered rings/ valvetrain causing poor compression?....i dont know how this could happen when it was running fine...then came to start it a few days later and its fukked
lol
lol
lol
lol
what were the plugs like that you took out?
could be valve stem seals/guides... my saff used to smoke on gearchanges and when idling for a long time... to the point that it would run on 3 for ages! it was okay after a good thrash though!
right, ive done a comp. check and all seems fine
no. 1= 149 psi
no. 2= 158 psi
no. 3= 160 psi
no. 4= 160 psi
i know no.1 s a bit low but nothing to worry bout, straight after i did the comp test...put the plugs back in and plugged the injectors back in and it fired straight up...
...another concern is, that its sounds like a diesel on start up? but compression is ok
no. 1= 149 psi
no. 2= 158 psi
no. 3= 160 psi
no. 4= 160 psi
good idea to look at your dizzy cap,rotor arm as might have got abit of crap in there!while there check your phase sensor wires check the insulation in the wires are all good!but to be honest imo sounds like wot said above coolant temp sensor
well, as said above it seems to be running fine now, was probably a dodgy map sesnor connection as i had a fiddle with that....there is a lot of piston slap when its started from cold though, only just really noticed....something to worry bout?
Aug 14, 2015 07:29 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
