starting probs
Old Apr 8, 2007 | 05:08 PM
jamie.patrick's Avatar
jamie.patrick
Default starting probs
having problems starting my focus
sometimes it takes several goes to fire it up
replaced battery, but no change, also had starter motor check and comes back as working ok
sometime you can hear a clicking when its turnig over so have now had a brand new starter motor but still the same
the car doesnt have an alarm if this helps?
any ideas...
Old Apr 8, 2007 | 05:11 PM
Is it a petrol or diesel mate.
Old Apr 8, 2007 | 05:31 PM
jamie.patrick
petrol, cheers
Old Apr 8, 2007 | 07:07 PM
Have u checked the simple things like spark plugs.
Old Apr 8, 2007 | 08:41 PM
jamie.patrick
yes, i serviced it the other day, also swapped the plugs around after service but no change
Old Apr 8, 2007 | 11:40 PM
Some suffered from bad contacts inside th ignition switch, I have replaced one that burnt out the contact completely, a known problem, but this usually causes a loss of power suddenly and randomly.
Old Apr 9, 2007 | 02:29 AM
jamie.patrick
i havent suffered a loss of power it just wont fire up first time
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
TPM961
Jan 15, 2018 10:50 AM
gcfcos
88
Sep 15, 2015 03:48 PM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
