Steering/Wheels?
Old Apr 8, 2007 | 04:04 PM
jamie.patrick's Avatar
jamie.patrick
Default Steering/Wheels?
Over the last couple of days i have noticed a little bit of shaking when i'm driving from the sterring wheel, its not too bad, gets a little worse the faster you go. could i just be the wheels need balancing or is it something else?
Jamie
Old Apr 8, 2007 | 05:09 PM
Well the first thing i wud check is 2 make sure the wheels r balanced up properly.u havent hit any pot holes in the roads causing the wheels 2 buckle have u?
Old Apr 8, 2007 | 05:32 PM
jamie.patrick
nope, not as far as i'm aware anyway
Old Apr 8, 2007 | 07:05 PM
Well i wud check the wheels 2 c if they need balancing first.
Old Apr 8, 2007 | 09:41 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
firstly, check the wheel balance, if it's not that, check for brake judder, as this can even affect the car when not braking
