RS500 owners
Old Apr 8, 2007 | 01:34 PM
adzbelcher's Avatar
adzbelcher
Default RS500 owners
Ive just been to my garage to start my car up and found to my horror that the oil pressure light was staying on. Ive climbed underneath and taken the oil feed pipe off, but theres no oil being pumped when the engine is running. The car has been stood for 6 months and was ok the last time I used it. Does anyone know if it is possible for the pump to run dry? Has anyone has this problem before and know how to correct it???
Old Apr 8, 2007 | 02:25 PM
Alvyn's Avatar
Alvyn
there is oil in the sump
Old Apr 8, 2007 | 02:46 PM
daz1968's Avatar
daz1968
I always remove my plugs disconnect injectors and coil, drain the oil and change filter then fill with new oil. Then I turn it over in short bursts until the light goes out. Once the light has gone out I then refit plugs and connect up all connections, Then I start it and leave it running for about ten minutes, It is surprising sometimes how much cranking it will take to get the light to go off after it has been standing for six months, You could remove the oil filter and squirt some oil down to the pump if you think it maybe dry, But I would not fire her up until good pressure is there
hope this helps
bobsworth
77
Mar 24, 2016 09:30 PM
Nov 1, 2015 06:53 PM
stephenb4506
33
Oct 2, 2015 06:25 PM
Kiran1600E
11
Oct 2, 2015 11:35 AM
rsguy
44
Sep 29, 2015 03:29 PM
