Escort GTi - Sluggish
Old Apr 7, 2007 | 03:06 PM
safetymatt's Avatar
safetymatt
Default Escort GTi - Sluggish
Hi Guys
I have an Escort Gti, just had it serviced and I mentioned that sometimes when I accelerate it sort of holds back then decides to go. So I had plugs and leads changed buts it still the same. Someone suggested the ignition coil may need changing as well, so I have one on the way.
Are they easy to fit is it something I could do? Any advice would be appreciated.
Old Apr 7, 2007 | 03:12 PM
Wardy257's Avatar
Wardy257
Disconect the MAF and see if she goes better.
Old Apr 7, 2007 | 03:23 PM
safetymatt's Avatar
safetymatt
sorry mate whats the MAF
Old Apr 7, 2007 | 03:32 PM
Wardy257's Avatar
Wardy257
The Mas Airflow Sensor. Next to your airbox, sometimes called a MAF.
Old Apr 7, 2007 | 03:37 PM
safetymatt's Avatar
safetymatt
and u can do this without effecting the car, what does the MAF do exactly
Old Apr 7, 2007 | 03:42 PM
Wardy257's Avatar
Wardy257
The MAF fine tunes the fuelling. The engine will run happily with just the TPS. If the car runs better with the MAF unplugged you can clean the inside of it out with carb cleaner, let it dry and try again.
Old Apr 7, 2007 | 03:49 PM
safetymatt's Avatar
safetymatt
thanks for the advice, i have ignition coil coming first so will try that, do u know if there are an easy thing to fit
Old Apr 7, 2007 | 04:09 PM
Wardy257's Avatar
Wardy257
Simple to fit, you can not go wrong.
Dr. Ickxs
Sep 15, 2015 10:15 PM
rogerxr3i
Sep 13, 2015 06:56 PM
bassboy
Sep 10, 2015 08:54 PM
imnoteasy
Sep 7, 2015 09:26 PM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
