N/A CVH ENGINE
Old Apr 6, 2007 | 10:11 PM
Vampire's Avatar
Vampire
Default N/A CVH ENGINE
whats the difference between a N/A cvh engine and a fiesta rs turbo engine?
i know the pistons are different, any thing else? crank? rods?
thanks for any help, trying to rebuild an engine from stratch, but having problems getting hold of a defo good fiesta turbo bottom end. and am basically hoping you can use any cvh bottom end, just change the pistons.
Old May 12, 2007 | 02:30 PM
tonto's Avatar
tonto
The turbo'ed CVH engine is low commpression and the normally aspirated CVH is high commpression.
Paul
Old May 12, 2007 | 05:42 PM
JesseT's Avatar
JesseT
Just change the pistons. Nothing very interesting otherwise. Pistons rings, gudgeon pins, oil return and big-end bearings are some of the minor changes.
Old May 12, 2007 | 08:06 PM
zippyobrien's Avatar
zippyobrien
blocks are exaclty the same arent they.
may asweel do a zvh or zetec turbo if your going to the trouble of building one from scratch
Old May 12, 2007 | 08:14 PM
SafeChav's Avatar
SafeChav
basic casting of the block is the same but they have differences.
I can quickly see this turning into another CVH vs ZVH/Zetec battle
s1turboman
Aug 29, 2015 04:27 PM
Marcus L
Aug 29, 2015 02:18 PM
Gadget
Aug 26, 2015 01:02 AM
knight19770
Aug 4, 2015 12:36 PM
