Focus 1600zetec
Old Apr 3, 2007 | 06:14 AM
slammedorion's Avatar
slammedorion
Default Focus 1600zetec
A mate of mine has a S-reg Focus... it has only done 60K, nice low miles for its age...
Its never missed a beat until last night on the way to work... it started missing on 1 cylinder...
I thought it would just be a plug... so after the night shift... finished at 6:15am... I decide to investigate...
It is missing on cylinder number 4??? furthest away from the cam belt...
It ain't the plug thats causing the problem not the lead eva... (process of elimination lol)
So I've decided to come away from the car because I'm tired... thought I'd rake the brains of you lot on here... most likely to be more awake than me...
Is it likely its gonna be the coil pack or what ever its called ( the bit where all 4 leads come out from... )
Or is there something else that could be causing it to have no spark to number 4...? ie a hidden EDIS unit...?
Any help would be greatly appreciated... hope you've all had fun reading my sleepy post...
Help...
Old Apr 3, 2007 | 05:57 PM
slammedorion
Coilpack then...? Ł65 quid from Ford... going to get one tommorrow unless anyone has got any other ideas...?
Old Apr 3, 2007 | 06:10 PM
The coilpack pairs two cylinders each side, ie it is two coils in one, each half of coil feeding two plugs so would affect two if it was that!!
If you have defo elliminated plugs and leads it leaves something mechanical, could just be a sticky tappet holding a valve open, or worse, do a comp check .
Old Apr 4, 2007 | 06:25 AM
slammedorion
This is one of the 1st Focus's... S-T reg... there is no spark going to number 4... I can pull the lead off with the car running, put a screw driver down it and earth it out on the block and still no spark...
Its gotta be ignition side... hence why I thought it would be the coil pack... ( or whatever its called? )
Old Apr 4, 2007 | 04:18 PM
slammedorion
Changed the coil pack ( as such )... and its sorted it... The part was just under Ł60 quid with abit of discount... you don't ask you don't get...
Old Apr 4, 2007 | 04:27 PM
Odd that, must have become disconnected inside as they feed two cyls, cars don't you just love them, nice to have feedback though, thanks.
Old Apr 5, 2007 | 05:41 AM
slammedorion
Ok no worries... its running like a new-en now...
wowk
Mar 30, 2021 07:49 PM
tankybaby66
Feb 6, 2016 02:24 PM
Sp3no
Sep 27, 2015 07:23 PM
Tank Mike
Sep 26, 2015 08:07 AM
