Bonnet problem!
Old Apr 2, 2007 | 07:29 PM
rs_racing's Avatar
rs_racing
Default Bonnet problem!
Hello.
I have fitted a 2.1 zvh engine with cvh efi inlet manifold and cossie throtle-body in my rst s2.
My problem is that there is not enough space between the throtlebody-linkage and the bonnet!
Have been thinking of bonnet raisers but are there anything else i could do?
Any ideas?
Old Apr 3, 2007 | 12:01 AM
SafeChav's Avatar
SafeChav
Big hammer?
Old Apr 3, 2007 | 03:49 PM
rs_racing's Avatar
rs_racing
No one else whit this problem?
Old Apr 3, 2007 | 03:50 PM
SafeChav's Avatar
SafeChav
A picture wouold probably help
Do you know how to post pictures?
Old Apr 3, 2007 | 04:13 PM
rs_racing's Avatar
rs_racing
I will take a picture tomorrow.
Hope I don`t have to use the hammer
Old Apr 4, 2007 | 04:07 PM
SafeChav's Avatar
SafeChav
Sometimes its ok to use a hammer
Old Apr 4, 2007 | 04:10 PM
rs nutta's Avatar
rs nutta
hammers are good tools
uurm would it be possible to skim the top of id down flat with a grinder as there quite thick if not i rekon your gonna need raisers
Old Apr 4, 2007 | 04:15 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
Can you not turn the throttle body around?
Old Apr 4, 2007 | 04:16 PM
SafeChav's Avatar
SafeChav
Now theres an idea
Old Apr 5, 2007 | 12:06 PM
rs_racing's Avatar
rs_racing
If I turn it the idle-speed valve will cause the same problem
Have been thinkikng if it`s possible to skim of a little at the throttle-linkage but don`t think it will be enough.
It`s the arm which is connected to the throttlecable that does not clear the bonnet.
Old Apr 5, 2007 | 12:31 PM
Tony Turbo's Avatar
Tony Turbo
This is how mine is;
And there is plenty of room under the bonnet.
Old Apr 5, 2007 | 12:33 PM
Tony Turbo's Avatar
Tony Turbo
The only problem is that to get to the ISCV you have to take the throttle body off and you can't get a plug in the ISCV either, so it is a very tight fit.
Old Apr 5, 2007 | 12:39 PM
CliffRS4's Avatar
CliffRS4
What about lowering the engine mount.
I know mine on my current spec had the engine mount altered so that the lump would sit lower.
Bit of a pain in the arse but still another option.
Bonnet raisers would be the cheaper option though
Old Apr 5, 2007 | 01:42 PM
SafeChav's Avatar
SafeChav
Surely though your engine must sit lop sided then, it would be incredibly difficult to lower the gearbox mounts aswell in order to keep the engine horizontal
Old Apr 5, 2007 | 01:49 PM
COSSIE CAL's Avatar
COSSIE CAL
get some raisers,god that would be so easy and save time
Old Apr 5, 2007 | 01:51 PM
SafeChav's Avatar
SafeChav
Tony, problem is, hes running a EFI manifold, theres not a lot of space when you use them, i think the fuel rail would probably foul the ISCV
Old Apr 5, 2007 | 03:53 PM
rs_racing's Avatar
rs_racing
I have now ordered some bonnet raisers from autospecialists. (more
bling bling)
Just need to secure to bonnet from popping up while driving then
Old Apr 5, 2007 | 04:58 PM
COSSIE CAL's Avatar
COSSIE CAL
nah just keep going lol,no need for bonnet pins got any pics of your car?
Old Apr 5, 2007 | 08:54 PM
rs_racing's Avatar
rs_racing
This is how she looks now
I might gonna do a project-thread when the car is finished.
Old Apr 5, 2007 | 09:38 PM
COSSIE CAL's Avatar
COSSIE CAL
needs a rs kit on it,your from norway!!dint no that
Old Apr 6, 2007 | 04:02 PM
SafeChav's Avatar
SafeChav
I like that, very different having the RS skirts aswell
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
Adam Graham
Sep 6, 2015 06:04 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
