Firing Order
Old Apr 2, 2007 | 03:39 PM
JimmyBoy's Avatar
JimmyBoy
Default Firing Order
There use to be a picture somewhere that showed you what leads on the dizzy connected to what sparkplug, anybody know the order or where I could find said picture.
Thanks.
Old Apr 2, 2007 | 04:28 PM
hodgie's Avatar
hodgie
going anti clockwise starting top right as you look at it..1,3,2,4 iirc
Old Apr 2, 2007 | 04:34 PM
Moonie's Avatar
Moonie
Old Apr 2, 2007 | 04:36 PM
addiction's Avatar
addiction
Old Apr 2, 2007 | 08:34 PM
homer j's Avatar
homer j
Originally Posted by Moonie
odd was certain mine was that pic but rotated ninety degrees clockwise
Old Apr 2, 2007 | 11:46 PM
SafeChav's Avatar
SafeChav
A lot of the diagrams floating around are wrong!
Best way is to time the engine up so number 1 is at TDC and remove the dizzy cap to establish number 1, then work round the cap anticlockwise in the firing sequence
Old Apr 11, 2007 | 04:12 PM
JimmyBoy's Avatar
JimmyBoy
That sounds a bit complicated for me!! lol
I have the leads on, but am getting no joy , I get the occasional "pop" out of the exhaust, but it wont start. Problem is, I dont know if its the firing order or some other problem. I tried disconnecting the Cold Start plug but that made no difference.
Old Apr 11, 2007 | 04:17 PM
SafeChav's Avatar
SafeChav
As i say, time the engine up so the bottom and top timing marks line up.
Remove the dizzy cap, and the rotor arm will be pointing pretty much at one of the connections, that is number 1!
Then as you look at the dizzy cap, working ANTI clockwise, fit number 3, then 4, then 2.
Fool proof, no guess work involved.
Old Apr 11, 2007 | 04:22 PM
JimmyBoy's Avatar
JimmyBoy
Thats the bit I dont understand lol, I feel like such a n00b
Old Apr 11, 2007 | 04:23 PM
SafeChav's Avatar
SafeChav
Dont be silly! You're better off asking than guessing!
Have you got a haynes manual?
Old Apr 11, 2007 | 04:24 PM
JimmyBoy's Avatar
JimmyBoy
yes, I have a haynes manual, I tired finding what I was looking for in there, but couldnt find it.
Old Apr 11, 2007 | 04:32 PM
SafeChav's Avatar
SafeChav
look in the first section "routine maintainence and servicing", you'll see "timing belt renewal", t will explain explain the procedure in there.
Basically there is a notch in the bottom pulley and a marker on the cam pulley which both need lining up, its very easy
Old Apr 11, 2007 | 04:35 PM
JimmyBoy's Avatar
JimmyBoy
Ok, thanks very much, i'll give it a try!!! , a mate said something like this earlier on and said you have to make sure it is on the compression stroke and not the exhaust stroke? is this right, how do I know - or is this explained in the haynes manual?
Just out of curiousity, do you do any damage cranking it over with the firing order wrong ?
Old Apr 11, 2007 | 04:50 PM
SafeChav's Avatar
SafeChav
If its not timed up right the marker on the cam pulley will be 180 degrees out as it spins at half the speed of the bottom end
It will be obvious when you read the haynes manual and look at the pretty pictures lol
Old Apr 11, 2007 | 05:22 PM
JimmyBoy's Avatar
JimmyBoy
Am I right in saying that if the firing order is 1,3,4,2 then this means I take position number 1 on the dizzy (once I have actually confirmed poistion 1 by timing it up) to the spark nearest the timing belt? Then position #3 on the dizzy goes to the 2nd spark plug (counting from the timing belt side), dizzy number 4 goes to spark 3 and dizzy 2 to spark 4 ?
Does that make ANY sense? lol
Old Apr 11, 2007 | 05:51 PM
Moonie's Avatar
Moonie
Position #3 on the dizzy in the next one round anti-clockwise from number # 1 and it goes to plug #3.
The cylinders/plugs are numberd from the cambelt end, #1 is nearest the cambelt and #4 is furthest away from the cambelt (nearest the dizzy).
So plug #3 is 3 along from the cambelt end.
Old Apr 11, 2007 | 06:00 PM
JimmyBoy's Avatar
JimmyBoy
So position number 2 on the dizzy goes to spark plug #2 ?
Old Apr 11, 2007 | 06:45 PM
JimmyBoy's Avatar
JimmyBoy
Will you do any damage by cranking it over with the wrong firing order ?
I did it earlier on and it made a few klonks & bangs so I stopped what I was doing as I didnt like the sound of it!
Old Apr 11, 2007 | 06:51 PM
SafeChav's Avatar
SafeChav
You wont do any damage.
You're making it more complicated than it has to be, find number 1 then work round the cap anti clockwise in the firing order.
Old Apr 11, 2007 | 07:19 PM
JimmyBoy's Avatar
JimmyBoy
Ahh, ok.
Well I did actually get it to fire up, but it was running like a bag of shit. I presume I either have got the firing order wrong or I have got an air leak somewhere.
Old Apr 11, 2007 | 08:14 PM
Fiecos Dan's Avatar
Fiecos Dan
1 --------- 3
Thats as it should be if you look at it from the passenger side, looking straight at it.
Old Apr 11, 2007 | 09:48 PM
Moonie's Avatar
Moonie
There seems to be two variations as to the position of the dizzy cap HT terminals.
Just had a look at mine.....
3---------1
4---------2
It seems from most posts (ignore the above pic) that #1 will either be at top right or bottom left (looking from passenger side) depending on which way roung the dizzy drive lug has been located in the cam.
Old Apr 11, 2007 | 10:27 PM
SafeChav's Avatar
SafeChav
WTF????????
You can only locate the dizzy drive lug in one orientation, number 1 is ALWAYS on the top side of the dizzy
This is why i said to time the engine up and identify number 1 for yourself.
IF you had it running - hold the revs and get it warm, its probably flooded itself with all the previous attempts to start
Old Apr 11, 2007 | 10:34 PM
Moonie's Avatar
Moonie
Is the drive lug offset?
Old Apr 11, 2007 | 10:36 PM
Moonie's Avatar
Moonie
In fact thinking about it i think it is
Its late, im off to bed...
Old Apr 11, 2007 | 10:38 PM
SafeChav's Avatar
SafeChav
Old Apr 20, 2007 | 06:59 PM
Fiecos Dan's Avatar
Fiecos Dan
WTF????????
Thats odd.
i've got a rst in my drive at the moment, and thats what i got the info off.
i'll check it at No 1 tdc, but its run ok before.
Old Apr 20, 2007 | 07:01 PM
Alex_86's Avatar
Alex_86
WTF????????
not if you have a 180 degrees turn on it like some have
Old Apr 20, 2007 | 09:16 PM
SafeChav's Avatar
SafeChav
WTF????????
180 degree turn on what?
Old Apr 20, 2007 | 09:31 PM
Alex_86's Avatar
Alex_86
WTF????????
hm, what could it be mate? the wheel? the dizzy!!
Old Apr 20, 2007 | 09:35 PM
SafeChav's Avatar
SafeChav
You cant fit them 180 degrees out the cam drive lug is offset, unless your talking about spinning the housing 180 degrees around but what would be the point in that?
Old Apr 20, 2007 | 09:36 PM
SafeChav's Avatar
SafeChav
actually that said it would still be at the top!
Just means the multiplug would be at the bottom not the top!
Old Apr 20, 2007 | 09:50 PM
Alex_86's Avatar
Alex_86
, if i only could explain this in Norwegian to you! then u would understand it.. as i am not very good in English, and specially technical words
so cant you borrow vroooom ptssssh translator
because: hvis tenningen er snud 180 grader vil timingen vćre forskjellig som det er postet her
2 --------- 4
1 --------- 3
som den ene har mens den andre har
3---------1
4---------2
noe som da resulterer til at den nederste har 180 graders vridd tenning.
u did not understand a word did u.
the timing at the bottom has a 180 degrees turned ignition
Old Apr 20, 2007 | 09:54 PM
SafeChav's Avatar
SafeChav
Yes.........but the only way to achieve timing 180 degrees out is to locate the locking key on the distributor, into the camshaft 180 degrees out, which isn't possible.
Do you understand what i mean?
Old Apr 20, 2007 | 10:01 PM
Alex_86's Avatar
Alex_86
not sure...or maybe i have read it wrong here....so you mean, that it is no cars(rst) with 180 degrees turned ignition/timing.
or do u mean that nr 1 on the dizzy is always on the top left?
Old Apr 20, 2007 | 10:06 PM
SafeChav's Avatar
SafeChav
Number 1 should always be on the top just because the dizzy can only be fitted one way, for obvious reasons.
No doubt someone somewhere has done something to fit it 180 degrees out but it shouldnt be like that
Old Apr 20, 2007 | 10:21 PM
Alex_86's Avatar
Alex_86
hehe, so you emit that some of the cars has it
thats all i need
Old Apr 20, 2007 | 10:50 PM
SafeChav's Avatar
SafeChav
Possibly some cars might, but its not meant to be like it and it wouldnt of been easy to do it because as i say the cam shaft locking key is offset.
Old Apr 21, 2007 | 10:39 AM
Fiecos Dan's Avatar
Fiecos Dan
But,
the elignment key on the dissy, could be turn round, as thats on a roll pin.
Old Apr 21, 2007 | 04:35 PM
SafeChav's Avatar
SafeChav
Originally Posted by Fiecos Dan
But,
No because its offset too far for the roll pin to compensate, the roll pin is only there to allow free movement because off the offset!
