efi erst running problems,anybody help please
ive converted my erst 2 efi and im having trouble with it,its got a jamsport head with a piper cam,ive also got a 195 chip and beige injectors,its running ofac management,the problem is if i try 2 move the car it coughs and splutters a bit but will clear but then when the turbo starts coming on boost it tries cutting out then if i ift of it returns 2 idle ok,i thought it might b due 2 not being setup so i tried it with blue injectors and unplugged the chip but still the same just ticks over a bit better,any body got any ideas please
Have you probed all of the sensor wires to make sure you have connections to the ECU? I had a different problem a while back and turned out to be a break in the wire. Also check the EDIS wires.
Chris
Chris
ive got the ofac map sensor as far as i know,is there any way 2 tell if its not atall,i used an xr3i loom and was led 2 believe 4 ofac management i didnt hav 2 change any wires about,is this true or not
check the part number on the map sensor with ford against a fiesta rs turbo. I cannot confirm the part numbers myself as sad as I am lol
You cannot use an xr3i efi map sensor, however the loom should work if wired in correctly
i read on rsbible that 4 the ofac management none of the wiring had 2 b changed maybe just cut 1 wire on the edis module so wud that b the cause bcause i havnt cut the wire,i got the map sensor from a bloke on another web site who was braking a fiesta rst and found out about the site cause the car was advertised as breaking in the parts section in this site,the map sensor looks the same as the xr3i 1 i will check part numbers 2 each other then give ford a ring
ok cheers,anyideas how 2 movw this subject into the rsturbo room anybody and also which colour wud that wire be as the wires dont hav any numbers on the plug next 2 them
Zoggon
Aug 10, 2015 10:39 AM
wud this show up on the setup when i get it done,any1 else got any ideas or had a similar problem atall
