sapphire cozzy playing up
Old Mar 29, 2007 | 06:27 PM
jlam's Avatar
jlam
Default sapphire cozzy playing up
hi, has anybody come across this fault
my sapphire 4x4 cosworth, mainly when backing off & going down hill when car is trying to hold back, has a bad jerking sensation. how can i describe this better feels like driving a car with the timing out or running out of fuel, has this fault in all gears, the lower the gear & the slower you go (especially between 20/40 the worse it is) when accelerating no probs,goes like s**t off a stick, nothing picked up when it was rolling road tuned but on rollers my opinion is, it is slowing down gradually & not trying to hold back, could this be a gear box fault be grateful to hear from anyone with this same fault
Old Mar 29, 2007 | 06:42 PM
CPS connector, do the old wiggle test, and you may find it is making/breaking contact within the housing.
New AMP connectors are available, PM me if you have trouble.
Old Apr 1, 2007 | 06:31 PM
YBJ's Avatar
YBJ
Thinking Cosworth..
What is the CPS and how do you do this test exactly?
Old Apr 1, 2007 | 07:12 PM
CRANK POSITION SENSOR, it's connector often plays up.
The only thing you can do is the wiggle test, whilst running.
Old Apr 1, 2007 | 10:10 PM
jlam's Avatar
jlam
hi
thanx very much 4 your answer but weve tryed that n it hasnt altered anything, so its a case of back to the drawing board
a lot of people seem 2 think it's backlash in the transmission
thanx again
Rsmat
89
Oct 12, 2015 07:50 AM
Fil
Sep 30, 2015 12:08 PM
martynhomer01
14
Sep 23, 2015 12:23 AM
Cos500
Sep 16, 2015 09:50 PM
ST-170
Sep 4, 2015 11:02 AM
