turbosmart electronic boost controller (SOLD)
apexi avcr
and i can tell you since having the boost controller setup i am so impressed power delivery is smooth and progressive.. the controller is part one of my plan to do 11s 1/4 mile runs... remember how i shoot off once i got grip? just imagine that from a stand still
Originally Posted by M K
but can the avcr do different boost in different gears like the turbosmart
the apexi learns your speed through your speed sensor and then adjusts the boost curve Accordingly i can still have 30psi in first gear but later in the rev range, so even if i use nitrous the boost wont come in as hard as normal. in order for the turbo smart controller to give different boost per gear there is a green and yellow wire which have to be earthed out so you can go from sp1 through to sp3, but you have to do this either by a switch or some sort of Solenoid Mechanism
Does it have it's own sensor or can it read off of my Spa speedo sensor.
I too am anxious to get the self learning going after reading the manual to see what it does
Originally Posted by Rick
the eboost 2 is the daddy, that has some mental control options!
nipper.1
Ford KUGA
12
May 30, 2022 07:39 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
