Max 'safe' boost?
Old Mar 29, 2007 | 01:02 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Default Max 'safe' boost?
What is the max 'safe' boost a ERST S2 can run without major engine mods? ie: pistons, crank etc...
Currently running 14psi 170bhp.
Cheers!
Old Mar 29, 2007 | 01:15 PM
r-s-turbo's Avatar
r-s-turbo
my bro has a turbosystems 195 bhp chip and it was setup up at 16psi so im guessing thats about the limit really???
Old Mar 29, 2007 | 04:05 PM
addiction's Avatar
addiction
18 psi with a decent intercooler is possible.
what is your spec to get 170 bhp at only 14 psi though??
Old Mar 29, 2007 | 06:05 PM
JimmyBoy's Avatar
JimmyBoy
Thought it would be reasonablly standard wouldnt it ?
Old Mar 29, 2007 | 06:13 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Current spec:
Scorpion Stainless Exhaust
Bailey Dump Valve
-31 actuator
K&N Induction
Ahmed Bayjoo chip
why would i need a uprated intercooler to run 18psi?
Cheers!
Rick's Avatar
Rick
how long is a piece of string? She'll take a lot of boost on a std bottom end if it's done right.
Old Mar 29, 2007 | 06:15 PM
JimmyBoy's Avatar
JimmyBoy
Originally Posted by Karlos G
Current spec:
Cheers!
Because your ACT's will go through the roof else, which will limit your power output.
Old Mar 29, 2007 | 06:16 PM
Karlos G's Avatar
Karlos G
Balls Deep!
How do you mean done right?
Old Mar 29, 2007 | 06:18 PM
JimmyBoy's Avatar
JimmyBoy
Balanced, uprated rods / pistons, ARP bolts etc...
A strong block in other words.
Old Mar 29, 2007 | 06:20 PM
Rick's Avatar
Rick
not just that, setup in a way as no detonation etc. But you are spot on in the fact that more boost can become counter productive.
Old Mar 29, 2007 | 06:25 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah i see your point, I just want to get the most out of it without going crazy on uprgrades.
So if for example i can gain another few horses by upping the boost to say 16 or 17psi without having any negative effects then thats what i'll do!
But if not....no worries i'll stay as I am.......for now
Old Mar 29, 2007 | 06:31 PM
JimmyBoy's Avatar
JimmyBoy
I thought 14psi was about the limit of a standard I/C, anything above that and the ACT's will just go through the roof?
Upgrade the I/C and you can turn the boost up further then, your next limiting factor is your pistons I suppose.
More boost = more stress on components, and the standard internals can only take so much.
Old Mar 29, 2007 | 06:37 PM
Rick's Avatar
Rick
if u goto 17/18psi, you will gain more torque, and possibly a touch more power. However, if u like driving flat out a lot, then don't bother. The temps rise so fast that you start to lose power, and your stressing the turbo etc. If you like an occasional blast in the lower gears then u'll be ok.
Old Mar 29, 2007 | 06:41 PM
Karlos G's Avatar
Karlos G
Balls Deep!
ok perhaps i'll invest in a bigger intercooler and maybe think about tweaking the boost then.
Cheers fella's!
Old Mar 29, 2007 | 06:53 PM
JimmyBoy's Avatar
JimmyBoy
Would be a wise choice.
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
SMILER258
Sep 28, 2015 09:04 AM
Russ Payne
Sep 25, 2015 08:29 PM
