At 4000rpm engine taking air (no fuel)
i had a sytec uprated fuel pump fitted to my escort cossy.and now when i reach 4000rpm it starts missing.like there's no fuel getting in, just air. i would appreciate any advice. Thanks
Sounds like you may have a engine sensor problem or corrosion in the loom or a dodgy contact somewhere and the ECU is in limp mode if it won't rev above 4000rpm.
Has the problem only occurred immediately after the pump was fitted ?
Thanks Guys.The pump was brand new and the problem started immediatly after fitting it.i'm taking the car to a guy next thursday to check out all the electrics and if there is nothing obvious wrong it must be a faulty pump.
Thanks again
Karl
Thanks again
Karl
ginner
13
Aug 30, 2015 08:40 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
ekjim
Aug 17, 2015 08:57 PM
