2wd saph cos miss fire ( new plugs still doin it :( help)
Team HOTHOT!
hey people posted up the other day for a mate ( milky cos on here ) about his 2wd saph cos , its stage 3 runs EA chip , as it got to 5k it was hittin a brick wall just missed it tits off every one said get some 071s well they come in the post yesterday gapped them to 0.55 as recomed to me took it out and still the same thing , will try new leads but what else could it be or is it a case of replacing the hole ignition system untill it stops
Originally Posted by CossieRich
boost limiter on chip being hit?
Team HOTHOT!
hope its not a boost limmiter been all the way dwn to 15 psi and still get it, spec is stage 3 , t34 2wd manifold , greens , 3bar map sencer , mongoose pipe with de-cat , EA 803 l6 chip
think its time to try some new leads and a phase its had plugs 071's dizzy cap and roter arm already not much else it can realy be
thanks
thanks
ok,
so its not the boost limit on the chip if its doing it at 15 psi.
Change Phase sensor (make a not of which way round the wires are when you remove) and gap it correctly.
Change CPS and gap correctly.
Originally Posted by Stu @ M Developments
Nobody bother reading my reply then? Oh well... not that i know anything about these cars anyway. lol
Maybe take some advice from this man, i imagine it stands a good chance he may have an idea whats up
Team HOTHOT!
thanks for the advise stu , comptly missed it the 1st time round working to much
thanks for the replys everyone
now how can this prob be solved like how do you adjust them so there in time ?
Stu dont worry about it i have told luke 3 time to look and replace it
also told him how much it was from you as thats where i got mine from
Luke was'nt it doing it on the std set up before milky went stg3
O tho did'nt use it for long as you know
Stu i still have'nt forgoten to get the new chip off you its more of the case of not having the cash and the engine has only just gone back in as Luke can tell you (he's been my "bitch" As Jay and Rich says
FlashRS
13
Aug 31, 2015 06:02 PM
