what rods when fitting calibra pistons..zetec or the cvh one
what rods do peopel use when they fit the calibra let pistons in ther zvh conversion do the pistons fit directly on to the rods with no mods
The bore of the small end needs to bored out by about 8 thou to give no interference measure it first !!!, a oil feel needs to be drilled in the piston from the oil control ring to the pin also the small end sides need to be skimmed so the small ends don't rub on the pistons, you skim 16 thou of each side
borboyous
Aug 22, 2015 11:17 AM
