I've acquired a Venturi dv off e-bay (hmm..), apparently it was running on an RS turbo and is suitable for a S1 or S2.
I've litterally just taken out my current bailey's dv and swapped it with this one, but with this installed it doesn't idle what so ever and just cuts out. I've also got another from a cosworth which I believe is single piston and therefore I wouldn't expect it to work. But this new one I would as I assume all RS Turbo's require a twin piston?
Well the advert said S1/S2 RS Turbo so I assumed that was an escort, but yes could well have been I guess. Is there an way I can find out just by looking at it?
That was the from the side, looking in the bottom is just black, it's spring loaded and needs to be pushed. Looking at the cosworth one I have as well they look identical, so trying to work out whether the internals are different. Can you actually tell whether it's single or twin just by looking at it?
