Group-A ALS throttle body housings
Old Mar 19, 2007 | 02:21 PM
Rippers's Avatar
Rippers
Monte Geek
Default Group-A ALS throttle body housings
Maybe a silly question but...
Why do they relocate the Air Temp sensor into the throttle body? Is there a particular reason?
Also silly question number 2
Are o-rings a superior seal over a gasket or it is because they are re-usable or something?
Old Mar 19, 2007 | 03:28 PM
ian sibbert's Avatar
ian sibbert
To prevent heat soak from the engine, and yes...lol
The rubber is to aid the swapping of any faulty parts quicky without having to scrape gaskets....same with the proper sump etc...all are done using 'o' ring material....
Old Mar 19, 2007 | 03:30 PM
Rippers's Avatar
Rippers
Monte Geek
Cool cheers Ian, fascinates me how much detail went into proper Group-A parts
Old Mar 19, 2007 | 03:49 PM
ian sibbert
As has been said any times on here before Paul, cost is never an issue when they build these cars....
Everything is of the highest, lightest and strongest specification.....
You should come and have look pal...lol
Old Mar 19, 2007 | 03:56 PM
...so were WRC head gaskets designed to be re used Ian?
Old Mar 19, 2007 | 04:10 PM
Rippers's Avatar
Rippers
Monte Geek
I think he means re-useable to the extent of say a item being faulty in a rally it could be swapped between stages. I would guess a head gasket going pearshaped is going to put you out of the rally full stop..
Old Mar 19, 2007 | 04:12 PM
ian sibbert
Phil,
The literature from Mountune IIRC did say they could be used again and as there is nothing to compress actually on the gasket, and assuming mating surfaces were true you would have no problems, but we change them everytime we rebuild regardless.....
Dont know about the cometic ones, as we only use Mountune versions....
Ian
Old Mar 19, 2007 | 04:23 PM
...cheers ian...i always knew they were reusable but all tuners used to mock me...LOL.
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
