Please help..
Old Mar 17, 2007 | 07:48 PM
GuGu's Avatar
GuGu
Default Please help..
Hello everyone..
I have a 89 ERST. I am restoring my RST. And I want to buy HKS Type 1 for turbo timer.. But here there isnt any rs shop.. So I need your help..
2 questions...
1- Can I connect turbo timer to my car?
2-If the first question's answer is YES, Can I use all functions of tuurbo timer.. ??? (The time datas of 0-100km,0-400m vs...)
Thanks for help...
Old Mar 18, 2007 | 01:51 PM
hodgie's Avatar
hodgie
Check with your insurance company about a turbo timer.. some companys dont allow them as far as i'm aware..
Old Mar 18, 2007 | 05:57 PM
rs shawn's Avatar
rs shawn
S1 Database Editor
All major insurance companies DO NOT have a problem with turbo timers. This has been quoted a few times and I don't know where people get their wrong info from. I've spoken to many companies regarding this issue and not 1 have said they are illegal to use or would they turn down insurance based on this. This includes companies like HIC, Adrian Flux, etc.
To answer your questions, yes and yes. BUT: get a good auto-electrician to fit it and you shouldn't have any problems.
Old Mar 18, 2007 | 06:17 PM
MattyRST's Avatar
MattyRST
I have a blitz dc3 turbo timer on my S2, and my insurance company insured me with it on the car, id go with what rs shawn said get a sparky to fit it !! Lucky mine came on the car so i didnt fit it
Old Mar 18, 2007 | 08:12 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
You could get all the fuctions working, but you would have to have a reliable speed signal. The best way would be to fit a decent speed sensor on a rear wheel so that wheelspin doesn't give you a false reading.
Old Mar 19, 2007 | 07:46 PM
GuGu's Avatar
GuGu
Thanks for the tip about speed sensor..
Thanks everybody..
Old Mar 19, 2007 | 08:16 PM
smitsturbo's Avatar
smitsturbo
you have pm GuGu
Old Mar 19, 2007 | 09:33 PM
GuGu's Avatar
GuGu
Originally Posted by smitsturbo
you have pm GuGu
Thanks.. You have pm...
I have another question.. What can I use as speed sensor?
Old Mar 19, 2007 | 11:19 PM
timturbo's Avatar
timturbo
what if u have cat 1 alarm can it still be used alongside with this
Old Mar 20, 2007 | 05:34 AM
Tony Turbo's Avatar
Tony Turbo
A dedicated wheel speed sensor. It is going a bit extreme though just for a turbo timer, but why not. Stack do one for example, but you would have to check if it would be compatible with the HKS.
Old Mar 20, 2007 | 08:40 AM
rs shawn's Avatar
rs shawn
S1 Database Editor
Personally I find that by the time I've got everything I need and get out of the car the timer has almost counted to 0 anyway so I then set the alarm.
I never boost it all the way home as I live in town and don't come on boost much doing 30 mph so the timer has auto-corrected to a lower count time anyway by the time I've pulled into the drive, opened the garage, driven in, removed phone - jacket - stereo, fitted steering lock, blah, blah, shut garage door.
I'm pretty sure some clifford alarms have turbo timer functions built in so it will set the alarm as well whilst the timer counts down, but you'd have to do some research into which ones. Unless your boosting your car to your front door there won't be much time betwen you sorting yourself out and the ignition being killed.
Old Mar 20, 2007 | 08:43 AM
rs shawn's Avatar
rs shawn
S1 Database Editor
http://www.clifford.com/
These 11 units have built in turbo timers:
http://www.clifford.com/Search/Searc...=turbo%20timer
If you already have an alarm it might be worth speaking to the manufacturer to see if they can help with sorting something out: they may already have a product which will allow correct operation.
R5FORD
Oct 22, 2010 07:54 PM
Jucks
May 4, 2008 03:52 PM
JanDK
15
Jun 8, 2007 10:48 AM
