figure this 1 out sum 1 plz
Old Mar 15, 2007 | 06:55 PM
TuRbO-CaB-LaD's Avatar
TuRbO-CaB-LaD
Default figure this 1 out sum 1 plz
battery keeps goin flat wen i leave it parked up for a day,(brought new battery 1 week ago) got multimeter was kickin out 12.35 wiv engine off, wen its runnin its kickin out 12.80, so i went scrappy got me alternator an it was same, so i put my other 1 bk on, also i hav noticed that wen i turn the ignition 2cd click i aint got no battery light that cums on like it always use 2
any ideas b4 i end up sellin my rs an gettin a subaru (joking)
Old Mar 15, 2007 | 07:01 PM
bassy_g's Avatar
bassy_g
check that blue wire that goes to the alternator
Old Mar 15, 2007 | 07:12 PM
TuRbO-CaB-LaD
hav dun mate both are on good,was told 2 check it earlier cheers
Old Mar 15, 2007 | 08:05 PM
SafeChav's Avatar
SafeChav
First things first if the battery light isnt working the alternator wont commence charging.
12.80 isnt a very high charge rate, a GOOD battery should read about 12.6 without the engine running!
Old Mar 15, 2007 | 08:15 PM
TuRbO-CaB-LaD
any idea how how i can get my battery light on wen i turn the ignition?
Old Mar 15, 2007 | 08:17 PM
SafeChav's Avatar
SafeChav
Check if the bulb is blown, if not there will probably be something wrong with the blue wire going to the alternator
Old Mar 15, 2007 | 08:18 PM
TuRbO-CaB-LaD
ok mate nice 1 cheers ill hav a go 2moz
Old Mar 15, 2007 | 08:21 PM
nellyscossy's Avatar
nellyscossy
turn on the ignition and earth out the small blue wire going to the alt..if light comes on then no probs with loom etc...no light chech bulb and blue wire continuity..
p.s. the correct wat to check an alternator isnt the voltage way..
you need to measure current which unless you have a posh clamp on meter means disconnecting the earth and puting a multimeter in series to measure the amps either charging or discharging..need a good meter though that measures dc current
Old Mar 15, 2007 | 08:23 PM
TuRbO-CaB-LaD
nice 1 for the info an tips mate ill take it on board
Old Mar 15, 2007 | 08:31 PM
SafeChav's Avatar
SafeChav
This man speaks the truth, but 12.8 is low for a running engine!
Old Mar 15, 2007 | 08:38 PM
TuRbO-CaB-LaD
last time i checked it wiv a multi meter, was few weeks bk an i was gettin 14 wiv engine runnin, few weeks l8r im on 12, change alternator get exactly same changed battery 2
Old Mar 15, 2007 | 10:40 PM
scotty86d's Avatar
scotty86d
earths???
Old Mar 15, 2007 | 11:07 PM
SafeChav's Avatar
SafeChav
If your battery light hasnt been working the alternator wont charge
Old Mar 16, 2007 | 05:17 PM
TuRbO-CaB-LaD
cleaned my earths, checked the bulb, followed blue wire underneath turbo an starter found it had split, joined it bk up an whooooooooo my battery light came on !! nice 1 lads 4 advice an tips id stil hav this problem if it wasnt 4 ya replys
Old Mar 16, 2007 | 06:53 PM
SafeChav's Avatar
SafeChav
Old Mar 16, 2007 | 07:13 PM
slimwynn's Avatar
slimwynn
this sounds familiar
Old Mar 16, 2007 | 07:17 PM
SafeChav's Avatar
SafeChav
Deja vous
slimwynn's Avatar
slimwynn
Eigdoog
48
Sep 19, 2015 11:03 AM
rsturbo27
Sep 1, 2015 09:54 PM
NoLeafClover
Aug 19, 2015 09:50 PM
no1trancefan
Ford Focus ST
Aug 6, 2015 05:09 PM
