2003 1.6 - Idle/Clutch Probs
Afternoon All
A couple of annoying probs
When first started, the revs seem a bit high and the car sometimes seems to 'pull' you along the road??
Also, when changing gear there is sometimes a 'squeaking' sound??
Any thoughts? Its my old mans car and he's been told these things are normal?
Originally Posted by STFUN
Does the "squeaking" occur when the clutch pedal is depressed ?
It's when you lift the clutch up after changing gear if that's what you mean mate?
Sounds like the pedal return spring. Adviseable to get it looked at. I had a TDCi Sport that started to do that, until the spring snapped ! That ended up with a new pedal box under warranty.
Cheers mate, glad I asked! I'll get it checked
Just my idling question to go
mk1focus
Ford Fiesta
Sep 24, 2015 06:19 PM
