rs/3i fuel pump relay
Old Mar 7, 2007 | 07:24 PM
GiRO's Avatar
GiRO
Care Free.......
Default rs/3i fuel pump relay
anyone know where i can get one? tried halfrauds, local ford place scrapyards etc etc... but they cant supply one.. gettin pretty desperate now as i use the car everyday so any help would be mint.
cheers..
Old Mar 7, 2007 | 07:27 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
if your needing a temporary solution to use the car, bridge these:
Ive got an S2 relay wired into my S1 as you may know its even harder to get an S1 relay, but it should be the same.
oh, this basically bridges the 12v live to the fuel pump so it runs constantly when you turn ignition to #2, please be aware that it wont cut the fuel pump in an accident touch wood!!
Old Mar 7, 2007 | 07:44 PM
mk1_orion_boy's Avatar
mk1_orion_boy
Do ford not do them anymore?
I managed to get one but about two years ago for £27 I think.
I tried 2 in mine and they both get quite hot if thats normal?
Old Mar 7, 2007 | 07:51 PM
Shings's Avatar
Shings
Is this not the same as the MK2 golf gti ?
Old Mar 7, 2007 | 07:55 PM
Shings's Avatar
Shings
both are Bosch K jet
Old Mar 7, 2007 | 08:58 PM
GiRO's Avatar
GiRO
Care Free.......
How temporary is temporary and how safe is that?
Old Mar 7, 2007 | 09:07 PM
SafeChav's Avatar
SafeChav
vroooom ptssssh ive told you a few times now you're not really meant to do that.
The ignition supply isn't designed to feed a pump that consumes 10A+ of current, additional to the fact the ignition circuits AREN'T fused
Someone is going to have meltdown one day from doing that.........
If you are after a relay i have a few second hand ones which work, im not using this as a sales pitch in any way, if you need one give me a shout
Old Mar 7, 2007 | 09:09 PM
vroooom ptssssh
It Wasnt Me!
SafeChav, You've never told me i'd have a "melt down" U jus sid it's not very safe in the event of an accident iirc as fuel pump would still run!
And fuck asking him for a Relay ive asked numerous times and he's not gave me a price or f'all
Old Mar 7, 2007 | 09:12 PM
SafeChav's Avatar
SafeChav
If you bridge it over to the permenant feed its unfused and you have to fuck about with shitty wires every time you want to switch the thing on or off.
If you run it off the ignition supply its also unfused, and not up to the job.
Either way...........its not ideal.
You've got no excuse really a proper S1 relay is only £25, which i've also told you numerous is times is far superior to the purple piece of shit S2's and XR3i's have.
Old Mar 7, 2007 | 09:13 PM
vroooom ptssssh
It Wasnt Me!
Can I just plug an S1 relay in tho? if so why's it changed to an S2 platform? fancy unblocking me?
Old Mar 7, 2007 | 09:20 PM
SafeChav's Avatar
SafeChav
You can't just plug it in, the pin pattern on the plug is the same, but the wires need changing around to different positions.
The reason your plug has been changed, i can almost guarantee is a result of having a wanky purple one plugged in to start with, they overheat internally, melt all their solder joints and eventually the heat conducts through to the plug and melts that aswell
Old Mar 7, 2007 | 09:23 PM
GiRO's Avatar
GiRO
Care Free.......
yep my one has melted
Old Mar 7, 2007 | 09:24 PM
vroooom ptssssh
It Wasnt Me!
Ok, so if I get a hold of one, could you tell me which wires go where?
Old Mar 7, 2007 | 09:39 PM
SafeChav's Avatar
SafeChav
Oh surprise surprise
Of course
Old Mar 7, 2007 | 09:41 PM
vroooom ptssssh
It Wasnt Me!
Of course
Spank you very much, Ive possibly got a guy with one...but not sure yet waiting on a return pm. Still got that ECU1 Radio here
Old Mar 7, 2007 | 09:44 PM
SafeChav's Avatar
SafeChav
Is a second hand one really worth buying though? How much is he asking for it?
Old Mar 7, 2007 | 09:46 PM
vroooom ptssssh
It Wasnt Me!
YH PM
Old Mar 7, 2007 | 09:59 PM
Shings's Avatar
Shings
IF this relay is the one that has the fuse on top of it- its the same as (i think) a mk2 golf gti
Old Mar 7, 2007 | 10:07 PM
SafeChav's Avatar
SafeChav
It doesn't have a fuse, but its a good point, any car with K jetronic should have this same same relay - like for example a Mk2 GTI
Old Mar 7, 2007 | 10:14 PM
GiRO's Avatar
GiRO
Care Free.......
back too the scrappie tomoz if thats the case then.. im gonna need big pockets
Old Mar 7, 2007 | 11:34 PM
It's Czech Mate's Avatar
It's Czech Mate
16i one has a fuse on top......still available from VW new!
Or Eurocarparts
Old Mar 7, 2007 | 11:44 PM
Billabong's Avatar
Billabong
Same as a Porsche 944, think they were cheaper from Porsche than Ford's too IIRC
Old Mar 8, 2007 | 06:32 AM
sm's Avatar
sm
shings your thinking of a rs16i relay which is the same as a mk1 golf gti
Old Mar 8, 2007 | 06:41 AM
se mk3 cabbie's Avatar
se mk3 cabbie
From where mate i couldnt find one anywhere
Old Mar 8, 2007 | 12:55 PM
SafeChav's Avatar
SafeChav
Maybe Ford have now run out then, but ive read loads of posts where people have bought new ones.
They appear on eBay very regularly..........
Old Mar 8, 2007 | 01:01 PM
Ginge !'s Avatar
Ginge !
just finding my feet
is anyone gonna tell this bloke he needs a new fuel pump as thats whythe relay melted or not ?
Old Mar 8, 2007 | 02:45 PM
SafeChav's Avatar
SafeChav
Ive had a couple of relays before that went high resistance internally due to cracked joints, but i agree a lot of the time the pump is knackered!
Old Mar 8, 2007 | 03:38 PM
Ginge !'s Avatar
Ginge !
what you mean a 15 year old pump,,,, that when it wears draws more current making the relay melt,,,,, or a 15 year old relay that failed due to a bald soldering joint,,,,,, but lasted 100k miles before it failed,,,,,,
its the pump, it will work again but you will need another one in 2 years average
Old Mar 8, 2007 | 03:43 PM
Cowboi's Avatar
Cowboi
my fuel pump realy just went on my nova.
its actually quite common but mine was because it got water in it.
u can probably take the cover off the relay and see the insides.
the tracks on the pcb may show signs, and will probably smell of a nasty burning/singeing smell.
only a blaitent sign or water damage or something similar would mean it definately aint ur pump.
because with electricity its now how much current u throw at a component. its how much it will pull.
so if the pumps fucked it would of pulled more than the usual 10amps or so and ruined the relay.
i'd be taking the relay apart right now and see what sort of condition its in.
a brand new original wehrle relay for mine was only £9.95
Old Mar 8, 2007 | 03:45 PM
Ginge !'s Avatar
Ginge !
id be buying a new pump first based on my 100k miles theory, falty parts fail quickly dont they ?
Old Mar 8, 2007 | 03:50 PM
Cowboi's Avatar
Cowboi
we'll he'll need a new relay what ever as his one melted.
unless the relay was full of water i'd check the pump out though. as there is probably a reason the relay went.
but if what was said above about the relays being crap and often going is right then might not be worth forkig out on a new pump if they are expensive.
could always run a cable from the battery to the pump, fuse it and put an ammeter on it and see what the pump is pulling.
Old Mar 8, 2007 | 08:26 PM
SafeChav's Avatar
SafeChav
Right largely i agree with you, the pump wears over time and gets to a stage where it kills the relay, but the relays are also of very poor construction inside and the solder joints crack very easily making high resistance as im sure you are aware.
But in the majority of cases yes, the pump more than likely will be knackered.
Old Mar 8, 2007 | 08:27 PM
SafeChav's Avatar
SafeChav
TeamGiroUnit, is the pump on the car loud when it primes?
Old Mar 8, 2007 | 08:57 PM
GiRO's Avatar
GiRO
Care Free.......
nope just buzzes kinda thing.. if that makes sense.
28 quid for a relay from ford
Old Mar 9, 2007 | 02:25 PM
SafeChav's Avatar
SafeChav
The buizzing should be veru quiet and gentle on a healthy pump, the one on my cabriolet was loud as fook you could hear it down the other end of the road when it primed
you've got PM aswell
Old Mar 9, 2007 | 03:18 PM
Ginge !'s Avatar
Ginge !
THAT MEANS YOU GOT NO FUEL IN IT YOU MONG
Old Mar 9, 2007 | 03:20 PM
SafeChav's Avatar
SafeChav
TRUST ME, it had fuel in it alright, EVERYTIME i turned the ignition on it was the same . I've still got the pump for comedy value, i'll send it to you if you like
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
155lee
Oct 24, 2015 11:11 AM
15
Oct 7, 2015 03:43 PM
tib2220
Sep 14, 2015 12:33 PM
