Where can I get a TOSlink optical PCB header?
Old Mar 5, 2007 | 12:09 PM
Thrush's Avatar
Thrush
Irritating c........
Default Where can I get a TOSlink optical PCB header?
Like this - just the little black toslink "box" that I can fit to a PCB?
Basically, I have one of these;
http://www.maplin.co.uk/Module.aspx?...=97124&doy=5m3
But mines the later one without the optical audio output
Now, I took it apart and looked at the PCB inside - it still has the space and the holes in it for an optical toslink header.....
So, I was wondering if I got hold of the header itself, could I fit it to the PCB to see if the firmware still supported it?
Pic of PCB;
Optical header spot is far left, next to the VGA output...
Old Mar 5, 2007 | 04:47 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Can RS components not sell you one?
edit:
Just had a peek on google - can't find anyone
Maybe solder on a phono header and stick a Toslink/coax adapter on it? Or just use coax?
Old Mar 5, 2007 | 04:57 PM
Thrush's Avatar
Thrush
Doubt a phono header would work, as I want it to transmit digital multichannel audio. Can't use coax, don't have a spare coax input, and don't fancy having to use the optical-to-coax converters (which are pretty shit and need to be plug powered!)
I've looked on Maplins site, Misco, Microdirect, Dabs, ebuyer - can't find fuck all!
Part number is TOTX173 or TOTX177, made by Toshiba. Found some for sale on an American website tho..... Fuck all here in UK - cept one place (Farnells) but they only do minimum order of £20 excl. VAT
Old Mar 5, 2007 | 05:31 PM
Rick's Avatar
Rick
get one from Farnell!
Just order some other bits. Unless you are in the trade, you're not going to get it cheaper.
Old Mar 5, 2007 | 05:43 PM
Thrush's Avatar
Thrush
Farnell don't have the 173, and I don't know if the 177 is what I need (to be honest,I don't know if the 173 is correct, but it's the only one I have found a picture of which looks right)
And I don't need £20 + VAT + del of bits either!!!!!
Nov 1, 2015 06:53 PM
Chas
Oct 5, 2015 07:13 PM
mpilk
Sep 27, 2015 09:21 AM
IainRS1700T
Sep 25, 2015 06:44 AM
dickdastardley
Sep 24, 2015 08:43 PM
