How to 'prime' a turbo before/when fitting it?
Need to re-fit my mates turbo back to my old fiesta.
Wondering what needs doing to make sure it doesn't fuck up in the opening stages of starting the engine?
Cheers.
Cheers.
disconect coil
place tub under oil return pipe
hold blades in front of turbo
turn engine over until oil comes out return pipe
reconect oil pipe
turn engine over for ten seconds
reconect coil
carl
reconect oil pipe
reconect coil
carl
its not worrying at all.....
the shaft/wheel assembly, sit in between 2 journal bearings, that are very very close to the shaft, but it literally sits there,....
holding the blades at the front stops the shaft from turning,....
will not cut fingers off etc,...perfectly fine to do so
carl
carl
Righto!
Cheers mate once again!
Will get it fitted today, and let the fun of blowing all the oil out of the exhaust begin
P.S. Got a friend at mountune to rebuild it for me in the end! cheers for your help anyway mate!
noooooooooo problemoooooooooo
has the fiesta got the newer oil return pipe,...
they become blocked real easy and collapse....worth getting a new one before fitting from ford, otherwise you ll still get the oil blowing past the back exhaust gas seal
carl
carl
Well when I went up to get a replacement (broke the other one
) they said they had to order one in. Thinking about it, I don't think my mate ever picked it up
So I'm not sure if it was a new or old styled one.
any pics of the newer modified one?
marky_g
Aug 15, 2015 10:43 AM
