My escort cos winter tidy up
Old Feb 28, 2007 | 11:37 PM
The Youth.'s Avatar
The Youth.
Default My escort cos winter tidy up
After I had returned from the ring in sept 06 my power steering rack failed so over xmas I removed it and replaced it, whilst it was out I took the oppertunity to degrease/ clean the bottom of the engine bay and crossmember, this then led to my to decide to remove the front running gear to get it all powder coated / painted
I painted the hubs by hand as I wanted the minimium thickness on the front of the hub to reduce any wheel wobble so on the back I used hammerite smooth and a spray version of it on the front face, I have access to a sand blaster so prepping them was made easy.
the bottom suspension arms were painted
the hub carriers and anti roll bar were powdercoated
parts painted /prepped
refitting begins
the caliper brackets were powdercoated and the calipers painted by hand in matching paint
I painted the disks in high temp paint after blasting them to reduce the chance of them rusting
the front is nearly finished now, just waitng for the brake pipe brackets to come back from the powdercoaters then the wheels can go back on.
whilst waiting for this tonight I started degreasing the offside floorpan, it is coming up like new!!
will post some pics of it tomoz
next winter I will remove the rear beam and paint/powdercoat the complete back of the car
steve
Old Mar 1, 2007 | 06:58 AM
JezSierra's Avatar
JezSierra
happy with that
looks good mate
Old Mar 1, 2007 | 07:29 AM
maxest's Avatar
maxest
Very nice!
Old Mar 1, 2007 | 07:49 AM
Sticky.'s Avatar
Sticky.
Looks good mate
Old Mar 1, 2007 | 07:57 AM
alanfordtw-15's Avatar
alanfordtw-15
cool i must do that with mine if i were you id do the back end now aswell such an easy job and rewarding reults for the rest of the year. only problem is keeping it clean
Old Mar 4, 2007 | 12:43 PM
redrsmk5's Avatar
redrsmk5
Hi mate, what are you using to degrease the floor pan? Your work looks very good!! god i wish i had a garage!
Old Mar 5, 2007 | 12:19 AM
The Youth.'s Avatar
The Youth.
Just using some normal deagreasant from the motor factors it's ok, but I am going to buy some propper"gunk" for the passengers side as that stuff is miles better than what im using.
steve
Old Mar 5, 2007 | 01:08 AM
Brian's Avatar
Brian
Brian
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
Chopshop85
Sep 12, 2015 06:42 PM
imnoteasy
Sep 7, 2015 09:26 PM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
Bighandsuk
Sep 2, 2015 05:23 PM
