URGENT: Alternator & Power Steering belts........
URGENT: Needed for SiB's car.........
I've got to get them this afternoon from local motor factors, so need the sizes (belt lenghts) for:
Alternator (twin belts) - 2WD set up
Power steering belt - 2WD set up
Anyone know the the belt lenghts please?
It it 900mm and 925mm ????
Originally Posted by Turbosystems
it says so on the belts doug
), they cut the belts (all of the belts - including the cambelt) with a stanley knife and threw them away............
i have a load of belts as spares, motorcraft ones,but they just have long part no. on,not sure which bit of that determines the specific type?? i can just list all of the numbers if you like?
Stu, Bud-weis, thanks for the offers.
I gave the motor factors reg number of a RWD Cossie, and I am 98% sure that I have the correct ones.
600 mm
and 614mm
Thing is, SiB now has an RS500 drop bracket fitted, so I dont know how that effects the alternator belt lengths
600 mm
and 614mm
PassionFords Creator
I gave the motor factors s reg number of a RWD Cossie, and I am 98% sure that I have the correct ones.
600 mm
and 614mm
600 mm
and 614mm
Will go upstairs and check stock.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
