YB Spigot Bearing.
Old Feb 21, 2007 | 11:43 AM
WD Pro's Avatar
WD Pro
Default YB Spigot Bearing.
How far do I tap it in ? i.e. flush with the end face on the crank or up to the step in the bore that stops it going any further ?
Please don’t just post the link to the manual as I did have that, but since work upgraded my PC I don’t have it anymore and they won’t let me download pdf’s
Cheers for any replies.
WD
Old Feb 21, 2007 | 07:42 PM
Measure the length of hole and the length of bearing, it may only go in one way depth wise as it may be at the bottom of hole when fully in ?
Old Feb 22, 2007 | 11:55 AM
WD Pro's Avatar
WD Pro
Thats the problem, the bore in the crank (after the taper but before the stop) is about 4 to 5 mm longer than the bearing. I am not sure if I should go flush with the outside face or right up to the step
Old Feb 22, 2007 | 05:09 PM
I would go flush as otherwise you will have to find something that is the PRECISE SIZE of the bearing outer dege to tap it but not bigger than the hole, flush will be fine.
Old Feb 23, 2007 | 07:53 PM
foreigneRS's Avatar
foreigneRS
Testing the future
should be tapped all the way in (use the old one as a drift).
if you don't tap it all the way home, the tapered shoulder on the gearbox input shaft could damage the needle roller case
Old Feb 23, 2007 | 09:28 PM
WD Pro's Avatar
WD Pro
Thank you
I would have used the old one but it was completely mangled by the time it came out
Still no excuse though for not mesuring how far it was in though before destroying it
Alloy wheels and ICE for sale
14
Sep 26, 2015 05:40 AM
redrsmk5
Ford Escort RS Cosworth
Jan 30, 2007 05:51 PM
abdr500
12
Apr 4, 2005 06:45 AM
Dilithium
Fiesta RS1800/RS Turbo
Mar 27, 2005 10:40 PM
Feb 4, 2004 06:31 PM
