engine prob' ... again
Old Feb 19, 2007 | 10:06 AM
Jack-of-all-Trades's Avatar
Jack-of-all-Trades
Default engine prob' ... again
hi,
This W-e my escort s2 broke down, I was driving for some test (3months of rebuild...)
the car accelerated then slowed down, impossible to drive at constant speed and the car starts to have HUGE back firing and don't drive... like fuel cuts
after a few seconds the engine died...
I tried to start the engine but don't hold the idle speed and there are massive misfiring in the inlet/ic pîping, the inlet was really hot ...
Today the car starts, but still misfiring in the inlet/ic piping
I do not include/understand any more, as soon as I finished repairing something, another thing breaks…
What's the hell ? for me it's a fuelling prob,isn't it ?
Thank you for your help and advices ...
Old Feb 20, 2007 | 10:25 AM
Jack-of-all-Trades
could that come from a shifted timing belt or a dead dizzy?
Old Feb 20, 2007 | 05:18 PM
zippyobrien's Avatar
zippyobrien
possibly shafted dizzy, but your rev counter would be possesed to,
maybe cam has jumped a tooth,
got a 5th injector???
and check your injector seals
Old Feb 20, 2007 | 05:36 PM
Jack-of-all-Trades
My rev counter displays nothing, the car won't idle, i can't say :/
I don't have a 5th injector, injector seals seems ok, they are not broken or something
The problem appeared suddenly, just after set up the actuator and removed the dump valve
engine bad acceleration, like micro cut, Full throttle -> huge back fire under the floor few yards after the engine died and the car stat but won't idle like a Co prob'
I will check the timing belt
Old Feb 20, 2007 | 08:11 PM
Dragsteer's Avatar
Dragsteer
I try to set co myself, then car wont start, when start car dying on road, wont go, missfires.....
I go to men with lambda and sort problem.
try see if timing belt is ok, best method is pull out spark, see if piston is in TDC then see position of other things.
Old Feb 21, 2007 | 12:35 AM
kurdt5's Avatar
kurdt5
similar problem i had with my s2...turned out i needed a new Distributer body.
Old Feb 21, 2007 | 06:26 AM
Not fuelling this is igntion causing it, as said first check cam timing then ignition timing.
If the belt has jumped the valves are open when they should be shut, heat has to go somewhere as you have found.
Old Feb 21, 2007 | 10:29 PM
zippyobrien
take the plugs out and see if one of them has melted, rare to happen i no, but still possible,
a similar thing happened to mine when the lower boost hose tore, have you checked this as it would expliane the huge pop.
other than that, get the dizzy checked out,
Old Feb 22, 2007 | 06:18 PM
Check for corona discharge and inside your dizzy cap, dry it out if wet.
Old Mar 18, 2007 | 11:31 PM
Jack-of-all-Trades
up !
The engine won't start, it tries but it won't idle
dizzy is ok
timing belt ok
there is not melted spark
it's fueling and got spark
I don't understand ... I'm going to break it, I'm really bored ...
If anyone have an idea ...
mk22door
49
Mar 26, 2022 07:15 AM
Bailes1992
Sep 3, 2015 02:17 PM
Bailes1992
Aug 16, 2015 07:14 PM
ray barker
Aug 7, 2015 09:00 AM
ginger1979
Jul 31, 2015 09:56 PM
